Old 11-25-2009   #1
RaptorReed
Drives: 1991 Galant VR4
What's Crackle Lackin?
Whats up? I stumbled across this place on google and figured I would check it out. From the looks it appears most of you are in Minnesota.
Anyway, short and sweet intro; I'm Tim, I drive a 91 Galant VR4 1350/2000 and for a living I'm in the navy working on Turboprop motors on aircraft up here in Oak Harbor, WA.
1991 Belize Green Galant VR-4 #1350/2000
The specs:
Engine bay
Stock motor at 170k
Evo3 Exhaust Manifold
Evo3 Ported o2 Housing
MHI Big 16g running at 13psi till I get bigger injectors
SD conversion - Tuning with DS-MAP
3" Exhaust - Megan Racing downpipe, high flow cat, and Vibrant 3"x3" dual outlet oval muffler
PS removed
Mesh screen intake
catch can
Aeromotive FPR
LC-1 Wbo2
Ostrich 2.0 Eprom Emulator
GM 3 Bar MAP sensor
GM IAT Sensor
Fullthrottle speed Speed density plug and play harness to connect IAT & MAP sensors to MAF plug
ETS Anodized Black FMIC 24x10x3 core and 2.5" piping
Non Cruise cable installed
EGR blocked off
Emissions crap all removed and unnecessary vaccum lines plugged.
Suspension, wheels and brakes
94' dsm rear subframe - old one was rusted out
3 bolt LSD
4WS removed
AMG Galant type 1 Wheels
Rear Trailing Arms Replaced - rusty and on the left one, the shock mount started shearing off from rust
Left Rear Lower Control Arm replace - old one was warped.
Rear calipers and rotors Replaced - originals rusted
Front Right caliper Replaced - original rusted and one stuck piston
Evo 8 Suspension
SS Braided lines Front/Rear
Interior/Exterior, and whatever else
Symbroski shift kit w/ 1g shifter
Custom two gauge din plate w/ Prosport (White/Green) Boost and Water temp gauges
Cracked Windshield mod
JDM Front bumper
JDM Facelift projector foglights
JDM Clear Corners converted to turn signals
Usual clear coat gone on roof, now starting on hood
89' Underdash with pocket
Not installed yet
New rust free gas tank with Walboro 255lph HP fuel pump.
New E-brake Cables
New Front rotors
Right Rear Dogleg
Future plans
Build new motor
Rebuild transmission
Rebuild Driveshaft
Replace Windshield
Find a Roof Rack
Upgrade to a Scoobie Alternator
JDM RS vented Hood
JDM Rear bumper
Fresh paint job
a few pics
In complete stock form at the dsm shootout 08'
Before new front bumper and wheels installed
With AMG wheels on
With JDM front bumper and fogs installed, inner fogs are wired up to the parking lights, Projectors to stock foglight switch.FMIC totally hidden from view now.
With High beams on,
RaptorReed is offline   Reply With Quote
