Old 11-06-2006   #22
Re: Dart Block
That could work for a drag only car, but you would need something cast for the street to be able to cool the cylinders.
Why? You'd still have to use sleeves since you obviously can't have aluminum cylinder walls. Water passages are water passages, material doesn't matter much. Unless you're talking about a solid block, which would be drag only. Or street/drag is your last name is Hess.
