Go Back   MitsuStyle > Hosted Support Forums > Elite Autosport
Old 10-17-2003   #1
We are having a sale on bolt-on Mitsubishi turbos from Precision Turbo for DSMStyle Members for a limited time.
SCM50 - $775
T04E 50-trim compressor wheel & cover - Stage 2(T31 69 Trim) or Stage 3(T31 76 Trim) Exhaust Wheel - .48 A/R or .63 A/R Exhaust Housing
Should support 400-470whp on race gas and high boost depending on your setup.
Options:
Internal Wastegate +$75
90 Degree Cast Alum Elbow +$25
Oil Feed Line/Return Line Kit +$100
PTE 680 Injectors +$310
SCM60 - $775
60-1 compressor wheel with a T04E cover - Stage 2(T31 69 Trim) or Stage 3(T31 76 Trim) Exhaust Wheel
Should support 400-525whp on race gas and high boost depending on your setup.
Options:
PTE 680 or 780 Injectors +$310
SCM61 - $775
56-trim Garrrett GT compressor wheel with a T04E cover - Stage 5(T-350 76 Trim) or T04 Exhaust Wheels Available
Should support 420-600whp on race gas and high boost depending on your setup.
Options:
PTE 780 or 880 Injectors +$310
T04S Compressor Cover +$100
Call and ask for Shane at Elite for availability. 612-521-0550
Old 10-18-2003   #2
john
Business as usual
john's Avatar
Damn, wish I had some money now. Those are some great prices.
97 Viper GTS
Old 10-18-2003   #3
john
Business as usual
john's Avatar
BTW, what turbo do you run Shane? 56-trim?
97 Viper GTS
Old 10-19-2003   #4
I have a 56-trim with a T04S cover, but it has a T4 exhaust side on it not a Mitsu. I haven't used it yet either.
Old 10-19-2003   #5
Iceman
How good are the internal gates good for(PSI). About 25 max?
Iceman is offline   Reply With Quote
Old 10-19-2003   #6
I don't know exactly. I know some people are running 28-30psi with the internally gated versions. Internals often have a trade off of not being able to run high boost stable or creeping at low boost. JET is running a PTE with an internal gate, I am not sure if he has tried to run over 24psi yet though. I am not a big fan of internals, you will get better spoolup with an external and usually get very stable boost control.
Old 10-20-2003   #7
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
I think on race gas it was holding 26psi pretty good. And probably would have held more but I don't know. It had to be ported out though cause it was creeping pretty bad but after Jet did that it was fine. External is definetly the way to go though, I am pretty sure he is going external when he gets a new turbo.
CRAIG
Old 10-22-2003   #8
john
Business as usual
john's Avatar
So, what all would I need to bolt one of these turbo's up? I have an external wastegate. So I would need turbo, feed line kit, and a cast elbow? Do I need a new manifold also (2g now)? Is the cast elbow to replace the o2 housing meaning I would run a manifold mounted wastegate? I planned on running it off the o2 housing.
Thanks, John
97 Viper GTS
Old 10-22-2003   #9
john
Business as usual
john's Avatar
BTW, what would you recommend on a street car? My goals are 11's on race gas.
97 Viper GTS
Old 10-22-2003   #10
The sale is for the bolt on Mitsu Turbos. No aftermarket Exh Mani needed.
Old 10-22-2003   #11
john
Business as usual
john's Avatar
Thanks.
97 Viper GTS
Old 10-22-2003   #12
A 50-trim is the best street/strip sized turbo out of these. The cast 90 degree elbow is usually used on 2Gs to make the charge air outlet similar to the placement on the T25 for hooking up to intercooler piping. On short route 1G intercooler piping setups like the Buschur, Indy Race Core, Victory, SLS, etc FMIC kits you don't usually use the elbow, they are setup for a turbo with its outlet pointing close to straight down.
Old 10-22-2003   #13
How does the 50-trim compare to the GT 56-trim? From what I have been hearing, the spool-up is only about 200 rpm slower. Doesn't it flow a lot more while being much more efficient?
Old 10-22-2003   #14
The 56-trim is going to spool quite a bit slower than a 50-trim. Should be a lot more than 200RPMs. The 56-trim is larger than a 60-1. It is close in size to a T61. The smallest exhaust wheel that they even offer for the 56-trim is a stage 5 compared to the stage 2 and stage 3 available on the 50-trim models. You could get a dual ball-bearing version (FP3065 or GT35R) for a fair amount more and possibly get better spoolup.
Old 10-22-2003   #15
john
Business as usual
john's Avatar
If I had my car tuned on a 50 trim and changed to a 60 trim, would the 60 trim be noticably faster? Sorry for all the questions, I only want to buy 1 turbo. I dont want to have to upgrade because I want faster. BTW, i am trying to get rid of my 16g, then I will have enough money. I dont want all my money tied up in parts which are laying around. Thanks, John
97 Viper GTS
Old 10-22-2003   #16
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Just get a 50 trim or get your car running with the 16g before "upgrading".
'04 Honda Ricer: stock
Old 10-23-2003   #17
The jump from a 50-trim T04E compressor wheel to a 60-trim T04E isn't that huge. Most guys step up to a 60-1 from the 50-trim. The T04E 50-trim actually flows more than a T04E 54-trim and flow similar to a T04E 57-trim, but it's more effiecient at high high boost levels than any of the wheels in the T04E family due partially to the exducer size of the 50-trim being slightly larger than the 46, 54, 57, and 60-trims. The 60-trim is rated to flow a little more than the 50-trim, but it might not be as efficient at 30psi from looking at it's compressor map. However it looks like part of the T04E 60-trim's comp map might be missing on the ones publicly available. The 60-trim should make a little more power though just because it can flow more air, a couple points of efficiency doesn't have a huge effect on power overall.
People have run 10s on 20Gs and 50-trims, people have run 14s on 60-1s, you have to have the rest of the setup and tuning to make full use of any large turbo. If you go bigger than a 50-trim, you are probably going to want to get your setup capable of reving to 8000 or 8500 and making power up there so that lag becomes less of an issue.
If you want a T04E 60-trim, we can get you one at the same price. I only listed what I thought would be the 3 most popular sizes.
Old 10-23-2003   #18
john
Business as usual
john's Avatar
I will probly end up with the 50 trim then since I have a completely stock 7 bolt. Want to keep that as long as possible. Or atleast until I snap a rod. Then, I will do the engine overhall. Thanks for the info. How long do you think the sale will go? Looks like I can get rid of my turbo when-ever I want. Hope to sell local though.
97 Viper GTS
Old 10-25-2003   #19
v8klla
v8klla's Avatar
So Shane how long is this thing running for?
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 10-25-2003   #20
Couple weeks.
