Old 01-24-2005   #1
Onefast99gsx
Question Anyone have access to Mitsubishi Part numbers?
Hey all,
I need a part number and pretty fast. I'll describe what i need. In side the transmission, you see the viscous coupler, when you pull the snap ring off and take the V.C. off, you then see the center diff. There is 2 steel balls that go in a hole on each side of the center diff. They mate with the shaft that goes to the Transfer case. I lost one of the steel balls. Can someone please help me???
It's a '99 Eclipse GSX.
I could also use the part numbers for the 2 transmission axel seals where the half shafts go into as well.
THANKS!!!
