Go Back   MitsuStyle > Hosted Support Forums > Elite Autosport
Old 10-27-2003   #21
That's a good price. Kinda makes me cry when I look at my FP invoice. :uh:
Old 10-28-2003   #22
Time to sell it and get yourself a nice 56-trim for the 2.4l.
Old 10-28-2003   #23
Don't tempt me. That purchase would probably put me in divorce court.
Old 10-29-2003   #24
The SCM50 is now available with a smaller .48 A/R exhaust housing for quicker spoolup. The normal Mitsu exhaust housing on the these turbos is a .63 A/R. PTE is only offering it on the SCM50 as of now.
Old 10-29-2003   #25
Shane, do you know how much bigger the outside of the T04S housing is compared to the T04E? I am just wondering if I can fit it in or not without a spacer plate. Do the stage 5 wheels on the GT56 cost extra?
Old 10-29-2003   #26
The T350(Stage 5) wheel is the basic and smallest wheel offered on the 56-trim. It doesn't cost extra.
Is your car apart? I could bring in my PTE T04S compressor cover and compare it to yours if its off the car. Or you could just measure the diameter across the backplate.
Old 10-30-2003   #27
My car is all apart. I don't have a lot of room, so if it is over 1/2" bigger I don't think it will fit. I will bring mine on Sat and compare the 2.
Old 10-30-2003   #28
Sale Ends Friday Nov 7th...
Old 10-31-2003   #29
PSI2HI
We bolted up a 60-1 hybrid w/ T04S cover to a 91 TSI and it fit just fine. I also had the turbo on my car for a few quick dyno pulls and it cleared mine as well w/o a spacer, although i did remove the water supply on the water pipe. PTE doesn't use it anyways so remove that and it should bolt up just fine.
Nick
Old 11-02-2003   #30
Was this a PTE turbo or a different one? I am just thinking they may mount a little differently. I looked at Shanes T04S and it looks like it should fit.
Old 11-02-2003   #31
PSI2HI
Mounted a SBR 60-1 w/ T04S just fine and then a 60-1 T3/T4 w/ TO4S cover just fine as well.
Nick
Old 11-06-2003   #32
Alright Shane, I am going to get a SCM61. I am going with the T04S housing and a 2.5" aluminum elbow welded on. So that should be $900, right? What exhaust wheel do you recommend for a 2.4 with 8.8:1 compresion? FRH manifold, HKS 272's, etc. I think you know most of my setup. I don't really know anything about the T4 turbine wheels that are available for it. I would like spool by 3.8k or so.
Old 11-07-2003   #33
Yea, it would be $900 for one setup for an external gate and the T04S housing. The elbows don't come welded on though, we would have to figure that out. I am not sure if a larger 2.5" 90 degree elbow would cost much more than than the 2" one used on the T04E covers. Hopefully its only a few bucks.
I am not sure about the T4 wheels, there are a few of them available and some of them have the same dimensions as some of the T350 wheels. I would probably do the T350 2.795"/2.437" exhaust wheel if you want it to spool decent.
Old 11-07-2003   #34
I will try and stop by Sat and drop a down payment off for it.
