Old 08-14-2005   #1
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Balance Shaft Removal.
Pros:
Less rotating mass, Less chance of the balance shaft belt failing and taking out the timing belt.
Cons:
More vibration from the motor, Pretty much have to pull the motor to remove them.
Thats about all I can think of so far. The vibration really isnt that bad, if you have solid motor mounts its worse but only around a certain frame of RPMs.
Just dont forget to put the nub in that replaces the rear balance shaft and gets bolted to the oil pump gear or chances are your motor will be toast within 100 miles!
Originally Posted by shoutbox
Old 08-14-2005   #2
plymouthPSi
Send a message via AIM to plymouthPSi
Dont Forget to Loctite the bolt that holds the gear on the turned balance shaft or it will go through your block..... haha
plymouthPSi is offline   Reply With Quote
