Old 11-13-2003   #1
john
Business as usual
john's Avatar
Does anyone a site with a how to on removing ac? I couldn't find it on vfaq.com. Thanks, John
97 Viper GTS
Old 11-13-2003   #2
Find AC parts and start unbolting. There are all the lines, the condensor, the compressor and compressor bracket, the evaporator, and the AC fuse box. That should be everything besides for wiring harnesses.
Old 11-13-2003   #3
Iceman
Is all the coolant out? I thought that stuff was bad to breath.
Iceman is offline   Reply With Quote
Old 11-13-2003   #4
john
Business as usual
john's Avatar
Yeah, I thought the same about the freon. Didn't want to breath in that stuff. That is why I am looking for a vfaq on it for some tips. Car is not moveable now so I cannot go somewhere and have it drained.
97 Viper GTS
Old 11-13-2003   #5
Enes
Enes's Avatar
there are what 3 major parts to it...
1. the one in the dash
2. compressor
3. behind the radiator..
4. you can also remove the belt tensioner which is extra 1/2 pound and it gets in the way..
5. all the lines
6. fuses
7. some wiring
so you are easily talking about 50 pounds savings..
-Enes
Old 11-13-2003   #6
Just loosen the lines and let the stuff vent to the atmosphere, it won't hurt anything. Freon and R134A don't do any damage to the enviroment (Freon actually contains components that help in the rebuilding of the Ozone layer).
Old 11-13-2003   #7
LightningGSX
Hellbound
1992 might still have r-12 in it, which is very harmful to the ozone layer.But neither r-134a or r-12 are poisonous, R-12 is heavier than air and can suffocate you though.
-Nulli Secundus-
Old 11-13-2003   #8
1994 was the first year of R134A in DSM's.
Old 11-13-2003   #9
This has actually been proven false since it was removed from cars in the US.
Old 11-13-2003   #10
on the awd's, don't remove the ac bracket unless you come up with a spacer for the carrier bearing mount. Not having that properly spaced can lead to drivetrain, and knock problems.
Otherwise, drain, and happy hacking .
Old 11-13-2003   #11
Iceman
Wait so there is no froen stuff in there? all this R talk is confusing but i got it.
Old 11-13-2003   #12
LightningGSX
Hellbound
Freon is just Dupont's trade name for R-12, The Dupont trade name for r-134a is Suva.So r-12 is freon and r-134a is not.
-Nulli Secundus-
Old 11-13-2003   #13
LightningGSX
Hellbound
I'm not saying you are wrong ,but I don't see how that could be possible.Sunlight causes R-12 to lose chlorine atoms, and chlorine breaks down ozone into oxygen.Where did you hear this?
-Nulli Secundus-
Old 11-13-2003   #14
Iceman
Alright easy enough. So he doesn't have anything to worrie about breathing wise?
Old 11-13-2003   #15
LightningGSX
Hellbound
The inventor of Freon used to inhale it just to show people it was safe.It can still suffocate you though, so just release it in an open area.
-Nulli Secundus-
Old 11-13-2003   #16
hes dead now isnt he?
Old 11-13-2003   #17
john
Business as usual
john's Avatar
Actually, I forgot. My car was converted to R134a before I bought it. The open area is going to have to be my garage I quess. Maybe I will turn on a big fan or something after I remove the first line and go inside for 5 minutes.
97 Viper GTS
Old 11-13-2003   #18
LightningGSX
Hellbound
He invented freon in the 20's so I would have to say he is long dead.I think he died from lead poisoning, he invented leaded gasoline too.
-Nulli Secundus-
Old 11-13-2003   #19
Enes
Enes's Avatar
Originally posted by LightningGSX+Nov 13 2003, 09:14 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (LightningGSX @ Nov 13 2003, 09:14 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-tpunx99GSX@Nov 13 2003, 02:54 AM
He invented freon in the 20's so I would have to say he is long dead.I think he died from lead poisoning, he invented leaded gasoline too. [/b][/quote]
abviously tried inhaling/drinking that too
