Old 10-07-2011   #11
Re: after 10 years its coming back to life
I pretty sure they did the swap
all I know the x-brace was cut out so the body was flexing with the top frame out. holes were cut in the car for the gas tank and for the rear end and the gas take holes were welded shut. the metal that was tryed to used as a patch for the rear end was welded very bad and burned through all over the place.
pics I took before Mike picked up the shell
did not take one of the damage on the drivers 1/4 panel. It was bad the body work was bad holes drilled in the sheet metal and pulled out that way and jut filled with bondo. the bondo started at the back of the door and went to the rear bumper and was thick. pretty sure that is why it was totaled out not a for a theft recovery
