Old 09-06-2010   #3
maperformance
Drives: EVO
Send a message via AIM to maperformance
Re: 24 HOUR AEM Labor Day Sale / Lowest Prices EVER on Full Product Line
__________________________________________________
Tru-Time Adjustable Cam Gears
AEM TRU-TIME Adjustable Cam Gears increase horsepower and torque without having to change the camshaft(s) and are must-have items for engines that are milled, forced induction, high compression and/or utilizing aftermarket competition cams. Our gears enable users to match cam timing with their vehicle's tuning state by advancing or retarding the cam profile in one-degree increments via true laser-etched markings. Precision-cut gear teeth ensure no premature wearing of the belt surface and AEM's anodizing on the gear teeth is lab-test proven as the hardest anodizing process on the market.
AEM TRU-TIME Adjustable Cam Gears are available in a multi-spoke, five-bolt design for most vehicles and our classic full-faced, three-bolt design for select applications. Five-bolt cam gears have an “8” in the suffix (23-8XX), and three-bolt cam gears have a “6” in the suffix (23-6XX).
Legal in California only for racing vehicles which may never be used upon a highway.
  • Increase horsepower and torque without any cam changes and are ideal for heavily modified engines
  • Grade-8, six-point hex bolts stand up to repeated adjustments and feature an integral washer flange for greater load distribution
  • True laser-etched markings on the leading edge of the gear allow for quick, accurate adjustments
  • Hard anodizing on belt surface is lab-tested as the most durable anodizing on the market
  • CNC-machined from 6061-T6 billet aluminum
  • Comprehensive installation instructions, recommended cam gear settings and decals included
  • Manufactured and assembled in the USA
  • For Off-Road use only
Fuel Delivery Components
Universal Adjustable Fuel Pressure Regulator
Universal fuel pressure regulator adapts to virtually any vehicle Interchangeable discharge ports match regulator output to output of any fuel pump
  • Adjustable from 20 psi to maximum fuel pump capacity
  • Patent # 6,298,828
Honda / Acura Adjustable Fuel Pressure Regulator
Our patented direct fit adjustable regulator for Honda/Acura supports flow and provides pressure for up to 1,000 HP.
  • Interchangeable discharge ports match regulator output to output of any fuel pump
  • No additional parts required for installation
High Volume Fuel Rails
AEM fuel rails are bored big to support fuel flow up to 1,000 HP.
  • Specifically engineered for each application
  • O.E. fuel pressure regulator or AEM adjustable fuel pressure regulator mounts directly to rail with no modifications
High Volume Fuel Filters
AEM's High Volume fuel filter supports flow up to 500 Horsepower.
  • Fits in stock Honda/Acura location or as a floating application on any vehicle
  • Large hexes machined into top and bottom for easy disassembly
  • No additional parts required for installation (Honda/Acura Only)
24 HOUR SALE! PM NOW for the Best Pricing on AEM Products that you have ever seen!
maperformance is offline
