Old 04-02-2004   #10
illz
Originally posted by Goat Blower@Apr 1 2004, 10:26 PM
We're all forgetting that you need to either resurface the rotors or buy new ones when putting on new pads. If you just slap a set of pads on, they will wear out in half the time since they weren't allowed to "bed in" with the rotors. Resurfacing or "turning" the rotors should be $15-$20 each at auto parts stores that do that, or new rotors are probably about $30 each if you shop around.
I'm sure your calipers are just fine, severely abnormal wear on the pads would tell you if there's a problem with them.
eh, what's your logic behind this one? no magic happens that mates the pad and rotor. if the rotor is still flat, unwarped, and the pads are the same size as what was on, you bed in the pads and are fine. hell, even that isn't terribly necessary, but to do it you just bring them up to high temp a few times -- 8-10 60mph to 5mph back-to-back-to-back-to-back stops (never stop completely just get right back up to speed) then drive around and let them cool, repeat with another series of 8-10, done. if you're using a high-temp race pad like a porterfield R4-E , do the same, but make them 100mph to 5mph stops
DSM + FWD = Carl Lewis in high heels
DSM + FWD + slicks = Michael Johnson in birkenstocks
illz is offline   Reply With Quote
