Old 04-07-2008   #6
Re: So about this cruise... What else do u need to do?
Mitsu housing turbos from PTE come with instructions showing where to run the oil feed line from on the oil filter housing. Garrett turbos need more oil than OEM Mitsubishi turbos and PTE has said the oil feed off the head isn't enough oil/pressure. Once you put the feed down at the oil filter on a balance shaft less motor, then the oil seals blow.
