Old 01-04-2006   #4
Re: Preload/play for shimming tranny...
Center diff case end play
.0031" - .0051"
Center diff side gear end play
.0020" - .0100"
Front diff case end play
.0020" - .0067"
Front diff pinion backlash
.00098" - .00591"
Front Output shaft preload
.0031" - .0051"
Input shaft end play
0" - .0020"
Input shaft front bearing end play
.0004" - .0047"
Input shaft rear bearing end play
0" - .0035"
Intermediate gear bearing end play
.0004" - .0055"
Intermediate gear preload (shaft)
.0031" - .0051"
Transfer bevel gear set backlash (output)
.0031" - .0051"
Viscous coupling end play
.0039" - .0102"
*All from page 22B-6 of the service manual for the W5M33 transmissions.
I can also let you know what part number you need if you tell us available clearances, of if you have the manuals they are on pages: 22B-7 through 22B-11. Torque specs are on 22B-12.
good luck.
