Old 06-07-2010   #881
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
So is Shane tuning this again this week sometime with the double pumper? Or is it just hanging there until he finds free time he doesn't have with a goal of getting it before your next event?
Old 06-07-2010   #882
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
That's the plan. The BlaqOPs kit is enabled and I'm hoping that with a good ground on the pumps and a full tank of fuel that he'll be able to tune the fucker. lol.
I told him to throw in the ID2000's and give me a 28psi/9k rpm tune. I must admit I waffled a bit about just going for 32psi but I want to drive it a while and make sure that everything is sound before I go for a max tune.
Old 06-07-2010   #883
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
32psi would be so much fun though
Old 06-07-2010   #884
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
One thing I never thought about really for you...is that you are doing road courses...you should really get a surge tank setup with all the fuel starvation issues people have seen.
Old 06-07-2010   #885
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I've deferred some decisions until I decide what my 'thing' is. This is my first sports-car and I just haven't had time to figure that out.
It's not a big deal to dump a 5gal can in the tank after each session for now.
Old 06-07-2010   #886
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Now I'm wondering if my oil burning (and dipstick spitting) is related to the catch can setup.
I did some research online but there doesn't seem to be a lot of consensus on how to configure them. I'm thinking that I might need to drill out the stock PCV valve and put an inline check valve on the outlet port of the can. Have to find someone that knows how to set that up right...
Old 06-07-2010   #887
Re: Evo X upgrades
Kracka vents FTW! Scheides would know how to hook all that up, he had them on his VIII.
Old 06-07-2010   #888
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Re: Evo X upgrades
We were talking about this when you were on the dyno. I think Scheides said it looked right tho...
Old 06-08-2010   #889
Re: Evo X upgrades
Could def ditch the stock PCV's for some Kracka Vents, these things are magic. I'll look at my car and see what the stock PCV's are like, I'm sure there's a way to circumvent them. If nothing else, you could put the KV's inline with them.
Old 06-08-2010   #890
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Would def appreciate that. The only one that I'm aware of screws into the valve cover (passenger front of it). Unless that Boomba can has a built-in check valve then the intake is probably pressurizing the can right now. I need to check that the next time I'm at DB.
The Kracka vents install inline on one of the hoses? I haven't ordered them yet...want to figure out what I'm going to do first.
Old 06-08-2010   #891
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Shane got my car on the dyno super late last night. He said it's "better" than it was but the progressive pump still allows too much back-flow when compared to a dual GSS342 setup. Said he could only get 200hp without the second pump turned on.
I'm tired of dinking with it. BlaqOPs has a Hobb switch in the mail so I'll just convert to the tried-and-true method. It looks like the progressive pump only works in the stock pump housing because the Y connector that he uses on that setup doesn't produce the back-pressure that the Full Blown housing does.
Old 06-08-2010   #892
Re: Evo X upgrades
Yup you'd just put the Kracka Vents between the catch can and IM, to keep pressure in the IM but allow vacuum to suck air from the crank case/valve cover. Talk to kracka before ordering, I bet he can get you them direct at a good price
Checking on the boomba can would be easy, just pull both of the hoses and blow through the one going to the IM. If you can feel *any* air coming out of the VC side, there's no checkvalve in there, and that's bad. The stock PCV can do some, but a beefier setup is def nicer.
Old 06-08-2010   #893
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
I'm tired of dinking with it. BlaqOPs has a Hobb switch in the mail so I'll just convert to the tried-and-true method. It looks like the progressive pump only works in the stock pump housing because the Y connector that he uses on that setup doesn't produce the back-pressure that the Full Blow housing does.
Well that sucks man...hopefully you get this sorted out. I think i heard your car on the dyno when Danny called me at like 8 pm, haha.
Those guys are going to need a vacation soon big time.
Old 06-08-2010   #894
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I have exchanged a couple PMs with him. I decided to go with another brand since I found some shiny, bling ones. I found some pictures of how they get installed and that couldn't be easier.
That was the plan! I'm not going to rely on it but I'm curious now because 'Hollywood' on EvoXforums was complaining about his Boomba can blowing up and not getting replaced under warranty. If they are getting pressurized then that would explain it but they have in/out ports on them so there might be a valve there.
Old 06-08-2010   #895
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
The email was at 11:30pm. When it's a two-guy shop then I imagine that vacations are difficult to take...
Old 06-08-2010   #896
Re: Evo X upgrades
LOL I had the set on my IX powdercoated gloss black.
Old 06-08-2010   #897
Re: Evo X upgrades
Same here, I heard a car on the dyno around 8:30, I was really surprised to get a call that late.
Good luck figuring out the fuel pump issues, I hate when stupid issues cause such large setbacks like this.
Old 06-08-2010   #898
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I got the new wiring harness (a Hobbs switch & relay) from BlaqOPs and I got half-way to DB when I remembered something....BlaqOPs had cut off the standard Walbro power connector in the second pump position because their progressive unit uses spades for the power connection.
Damn. I drove back home and just sent an email to Full Blown. I hope LJ can hook me up.
Old 06-08-2010   #899
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
LJ has what I need. I'll go to DB after work tomorrow to swap in the new setup.
Old 06-08-2010   #900
FullBlown
Drives: evo x, honda s2k
Re: Evo X upgrades
We stock a bunch of them. Swing by anytime Mike.
FullBlown is offline   Reply With Quote
