Old 05-21-2010   #701
311evo
311evo's Avatar
Re: Evo X upgrades
sucks man, good luck getting it all sorted out.
I think someone needs to invest in a jack?
ignore the hate, it's just people feeling superior for whatever lame reason.
Old 05-21-2010   #702
Re: Evo X upgrades
Welcome to DSMStyle!!! Where when you screw up, people let you know rather than giving you some sugar-coated response.
Just learn from it, take the comments for what they are and just move onwards and upwards!
Just be glad no one has brought up flamadation valve issues to you yet
Good luck and hopefully their is no real damage.
Old 05-21-2010   #703
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
That was a good zing, gotta admit.
I would have laughed if any of my friends on here said it.
The first thing I did, of course, is to Google the matter. The manual says 5 quarts. Valvoline used 5.1. Consensus on the forums is to use a little less, perhaps 4.8.
Shane thought it was a quart over. It must have been due to heat expansion while on the dyno because 4.1qts would put it at the bottom of the fill line, I should think.
It didn't pop the dipstick while I had it but I kept it under 5k rpms.
Old 05-21-2010   #704
Re: Evo X upgrades
Yep, the condescending comments lately are getting old. This is MistuStyle, not NABR.
Old 05-21-2010   #705
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I have a nice one...some of the guys used it on the newb mod day. I don't have a garage and buying one of those isn't in the budget right now.
Old 05-21-2010   #706
Re: Evo X upgrades
Even if you put 5.5 quarts in it, I doubt that the turbo return line would be covered up, if it is, thats a crappy pan design. Filling it to the max is common so I dont know if thats the issue here.
Old 05-21-2010   #707
311evo
311evo's Avatar
Re: Evo X upgrades
I've changed my oil outside more times than inside. :P Totally worth it, just to have the piece of mind that you knew what came out, and what went in.
Old 05-21-2010   #708
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
Bummer...i was actually thinking of heading up to DB today to check the dyno tune out.
So is he putting the car back on today at all?
Old 05-21-2010   #709
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: Evo X upgrades
+1. I think it would need to be quite a bit over to cause any real damage. Haven't worked on or even seen the motor on a X though.
BTW, how did the car lose the oil?
7/25/09
Old 05-21-2010   #710
Re: Evo X upgrades
The only time you would be able to get the factory capacity into an oil change is with a totally dry motor. Like a new build with a totally dry/clean oil pan, dry oil cooler, dry, oil cooler lines, etc. Most of the quick change oil places are also not going to let the oil drain for 15 mins either and try to get as much out, they will pull the plug, let it drain quick, throw the plug back in and then if they put in the factory oil system CAPACITY, then you might have too much. Too much oil can blow turbo seals, other engine seals, rod HP, etc. The turbo oil return lines are usually right at the oil level and it you unhook it with the car off, oil will drain out. With the car running the level will be a little lower and allow it to return ok. A little bit too much and the oil starts to back up into the return line.
Old 05-21-2010   #711
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Ignorance bit me again. Valvoline put a quart too much oil in at the last change and I didn't know that being a little too full is very bad on turbo cars.
Swifty coated DB's dyno with coolant and very late last night my car covered it and my engine bay in oil.
FML. Only got one pull in...said it did 350 at wastegate (21-22psi).
Sounds right for power, i checked my thread and i hit 355 at 20psi, checked my "twitter" feed in my thread, lol, when i was posting all the results.
Damn it, i wanna see what this makes.
Old 05-21-2010   #712
Re: Evo X upgrades
+1 keep it above the belt guys, maybe a little higher.
Old 05-21-2010   #713
Re: Evo X upgrades
So did the dipstick just blow out, and that is what covered things in oil? Blowing out a dipstick on these cars isn't the most uncommon thing ever.
Old 05-21-2010   #714
Re: Evo X upgrades
Yea, it blew the dipstick and then a geyser of oil shot out. Kinda like a 4G63, but instead of a little spray, it was a fountain.
Old 05-21-2010   #715
311evo
311evo's Avatar
Re: Evo X upgrades
Was this the new performance lube BOV I've been hearing about? get's ya vtec numbers from what I hear..
Old 05-21-2010   #716
Re: Evo X upgrades
Geebus. I'm trying to imagine if that would have happened and you had you're cool little "knock headphones" on and your head down in the engine bay, and BOOM OLD FAITHFUL IN THE FACE!!! Man that woulda been rough!
Old 05-21-2010   #717
Re: Evo X upgrades
Better consult Kevin Costner.
Old 05-21-2010   #718
311evo
311evo's Avatar
Re: Evo X upgrades
Sounds like my friday night.
(LOL)
Old 05-21-2010   #719
Re: Evo X upgrades
(LOL)
Hahaha! I don't think I even want to ask
Old 05-21-2010   #720
Re: Evo X upgrades
Hmmmm I would think she would say that, and not he? hahaha
