Old 05-04-2010   #181
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: 1992 Eagle Talon TSI Project
I'm pretty sure its not suppose to roll if its in gear... I could be wrong though.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 05-04-2010   #182
Emergency brake! (car tends to roll down the driveway if i just keep it in gear where i need to actually put a peice of wood behind the wheel.)
Please explain. If you put it in gear it still rolls?
Old 05-05-2010   #183
GsXtUrBo98
GsXtUrBo98's Avatar
^ Exactly
98 GSX (built)
03 BBY EVO dd
Old 05-05-2010   #184
LingLing
AznKraut
LingLing's Avatar
How far do you have to pull your e-brake up when you engage it? if it goes all the way back and it's really loose you probably need to adjust it. Easy fix. I adjusted mine and now it holds like a champ.
Old 05-05-2010   #185
if ajusting the cables does not work. it will be time to get new rear brakes
I have a p.s. pump in one of the bins and a full p.s set up
Old 05-05-2010   #186
No you guys dont understand... I have NO FREAKIN E BRAKE. No cables, no arm, no ebrake period. LOL
It only really rolls when its in 2-5th. Same thing that happened with jasons car when he fell on his face chasing after it.
and mark, i will take that full power steering setup from you. (Dont need the actual rack though.)
Old 05-05-2010   #187
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Wish you had a video of that fall
Old 05-05-2010   #188
LingLing
AznKraut
LingLing's Avatar
Screw you guys
Old 05-05-2010   #189
Bahaha I can picture that too.
Old 05-05-2010   #190
LingLing
AznKraut
LingLing's Avatar
Power steering's for poofs. You drove my car, it's not that bad. Plus you gain +40awhp when you're in VTEC.
Old 05-05-2010   #191
well... took my first highway pull...
It started to overheat. So i limped it home and stopped once to let it cool down on the way home.
so im thinking its:
A) the headgasket (i hope not and please no i told you sos)
B) Not enough coolent in the system
c) Thermostat stuck closed
It heats up incredibly fast from full cold to right in the middle in around a minute.
And i think the idle surging has to do with the coolent lines not being hooked up to the FIAV. So i will probably just block the FIAV off and call it good.
Old 05-05-2010   #192
I would get a new thermostat and burp the system real good. Then go try it again.
Old 05-05-2010   #193
You are some kind of OG noob aren't u?
Old 05-05-2010   #194
I, Tom Ferlaak, Would like to apologize to the members i doubted that you should not reuse a head gasket. I realize that even though in the past this has worked. this is just not the case in this situation. From this day forward, when the head comes off, the head gasket will be thrown away.
Thank you for your time,
Tom
Old 05-05-2010   #195
TYS, apology accepted.
Old 05-05-2010   #196
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
LOL, can't believe you actually re-used it. How is the polished exhaust mani going?
7/25/09
Old 05-05-2010   #197
hahaha
Old 05-06-2010   #198
Oh boy.
Old 05-07-2010   #199
It hasnt rusted. but it turned a cool copper color. i dont know if it was from the FP bolts that like somehow did an anodised thing to it, because the bolts turned gold and the mani turned copper. lol
Old 05-08-2010   #200
Ok so two things that may be causing the car to seem to run hot.
a) The Coolant dump line from the turbo is coming in to the Thermo Housing right above the sensor.
b) I think the overflow tank is mounted upside down. (there are no markings on this summit catch can as to which end should be up and the overflow tank is empty but spits out coolant every time i stop.)
What do you guys think? it wasnt overheating. it was just running a bit hot at the slower speeds this time and would cool down when i cruise at higher speeds. right now i dont have a thermostat in.
