Old 08-19-2006   #21
Re: Street car build-up please help!!
2.4L
FP3052
HKS 272/272
Enough said
Old 08-19-2006   #22
Originally Posted by Super Bleeder!!
mk4 supras have getrags, so they cant all be bad.
Yea, they never ever break in Supras either and the faster Supra guys never swap them out for Powerglides or TH400s.
Old 08-19-2006   #23
ryan woon goes pretty fast on his
but heck, even shep has a ford 9" now. american driveline ftw?
Old 08-21-2006   #24
Hoffer00
Fight Man Champion! Cantankerous Tank Champion! Go Johnny Go Champion!
Send a message via Yahoo to Hoffer00
What about a 2.3. I thought those were supposed to be really good power handlers.
Hoffer00 is offline   Reply With Quote
Old 08-21-2006   #25
Yeah I should just go 9", it's the in thing .
Old 08-21-2006   #26
Black97civic
35mpg
Yeah, swanny I am gonna have to agree with you, powerglide and a ford 9" rear end FTW.
Old 08-21-2006   #27
Shotgun!
Totenritt
Shotgun!'s Avatar
You are forgeting the VPC. You have to have a VPC with your FoMoCo 9" and GM-PG
Old 08-21-2006   #28
well so far, its looks like 2.0L, and B16G, if i need more then a 50 trim. Now the question is stock internals or aftermarket for insurance?
Old 08-22-2006   #29
Stock internals will be cheaper and have better longitivity if you are doing a 2.0L with a B16G aslong as you keep a safe tune and aren't trying to max things out.
Old 08-22-2006   #30
Stock internals are dandy, you won't need to upgrade until you're making more than 500whp consistantly.
Old 08-22-2006   #31
Hoffer00
IS the 2.3 stroker a good engine. or is the 2.4L better.
do they both fit AWD
I don't mean to highjack the thread
Old 08-22-2006   #32
Theoretically, they cannot handle as much RPM as a 2.0 motor can, because the rods are longer and the crank is bigger (basically). They can make a TON of power though, and yes, they'll all fit in an AWD car b/c they are all basically the same on the outside!
Lots and lots of info on this around the net and on this site, do some searching for more research.
Old 08-22-2006   #33
Hoffer00
Smile Re: Street car build-up please help!!
thanks for not butching me
Old 08-22-2006   #34
There is about .5l displacement difference between the 2.3l and 2.4l motors, depending on what you do for overbore. They both use the same 100mm crank. The difference is in bore size, if you use the 2.0l block, then you get a little less displacement, unless you went to a huge overbore. 2.0l blocks have oil squirters stock, you can have oil squirters put into the the 2.4l blocks also though. To run the long stroke in teh shorter deck 2.0l block, you often end up with the oil control ring of the piston partially cutting into the wrist pin area. Both motors suffer from the same high piston speeds and poor rod ratio due to the crank.
Old 08-22-2006   #35
If you are wanting to stay stock or low budget on the internals, build the 1g 2.0L. But if you are going to buy pistons, then do the 2.4L. Go for the larger displacement and torque? It cost the same unless you are going all out. Torque is what moves a car. Keep the rpm under 7500 and it will live just as well as a 2.0L and be more fun to drive.
Old 08-22-2006   #36
...except piston speed is a lot higher in the 2.4L compared to the 2.0L so that will negatively effect engine life.
Old 08-22-2006   #37
True but the differences at 7500 won't be noticed until very high mileage, who actually keeps their dsm running for 50+k?
Old 08-22-2006   #38
My engine lasted until 162k, had I decided to rebuild it instead of parting it out I would have expected the same. Rembember guys, Aaron wants this car to be a reliable DD and with the driving a lot of us seem to do 50k miles only seems to be about 2 years worth.
Old 08-22-2006   #39
I would say we could easily build a forged motor that will get close to 100k on it for rounds.
Performance and reliability and budget never go together. Most people can usually only afford 1, 2 costs real money, and 3 is never heard of.
Boost and horsepower also negativly effect engine life as well .
Old 08-22-2006   #40
At-Least-It's-An-Evo
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Exactly. It shouldn't even be the engine that you'd have to worry about ageing. It's the rest of the car. It'll fall apart within the next few years anyways before the engine goes.
