Old 12-12-2011   #1
Winter plans/mods 2011
What's everyone up to car wise and i guess otherwise since this isn't much of a car/tech forum anymore.
I moved and we are cleaning the garage up to get my car inside and then I'll be installing a few parts that I've had laying around for a long time. (ES bushing kit, '06) Apart from that I'll just be cleaning up the car and fixing small leaks and things I don't like.
Apart from that score a fulltime job and maybe move again depending on where I get employed.
Old 12-12-2011   #2
Re: Winter plans/mods 2011
Car wise, I'll probably need new tires later this winter and at that time I might do a Whiteline Roll Center Kit. Other than that just gas and maintenance!
Old 12-12-2011   #3
Well, I moved mine out of it's nice spot in the garage to outdoor storage, hopefully I'll be more motivated next spring. Just don't really care about it right now.
Old 12-12-2011   #4
going to get the spyder done and ready to go by spring.
start working on the evo some more. get the rear end back in it. also have to have the 2.4 block machined, get a head done and get a set of cams for it
Old 12-12-2011   #5
Probably do another oil change in 5k miles, since I just did one. That should put me safely at spring time.
Old 12-12-2011   #6
Be careful you don't get too dirty.
Old 12-12-2011   #7
Swapping in a full 3" exhaust with quiet/loud switchable mufflers, and maybe a wideband.
Oh and maybe this if I get motivated:
Old 12-12-2011   #8
Tachyon
Tachyon's Avatar
Drives: Icarus
I'll need to pull the engine to drill out the 2 center bearing bracket bolts on the drive shaft I sheered off. Then I should probably rebuild my prop shaft as it's making quite a racket since installing solid bushings. I also need to replace the seals on my power steering rack... they finally gave up the ghost after 21 years.
For fun stuff, I've got fully poly bushings for the rear end, including the moustache brace. I also am planning on lighter 17x9 wheels with 255 wide rubber on all 4 corners.
-Sebastian Vettel
Old 12-12-2011   #9
cmspaz
Walls need hugs too
cmspaz's Avatar
I'm at a point where it's just finishing touches. Once everything current works correctly, GrimmSpeed 3-port BCS and Omni 4-bar MAP sensor, speed density tune with a high and low boost maps so I can just leave it alone, and then just driving and enjoying it.
Hopefully by spring get the blown MR Bilsteins I picked up rebuilt and revalved for Swift Spec-Rs, and probably just solid sway bar links in the rear to give it a little more stiffness and less roll/play. T-case rebuild in there somewhere too before Proving Grounds.
Originally Posted by Trogdor
Old 12-12-2011   #10
Scott
Drives: 2011 WW Evo X
I'm hoping to do a 3" TBE and get everything ready for an e85 switch and 3port for a tune by spring.
2011 WW GSR
ETS intake
ETS UICP
Perrin shorty antenna
Scott is offline   Reply With Quote
Old 12-12-2011   #11
93gtpeater
Drives: cbr 1000rr repsol
I plan on going 35r and having my center welded this winter. proably upgrade injectors since those are maxed out. Would like to change my cams out for some 280s. If its together in the spring I can get my cage weleded in
Old 12-12-2011   #12
mondale
Drives: 1g dsm
Start the swap to automatic soon. Attempt to save up enough scratch for a nice roll cage. Re-upholster the front seats so they look nice again! And make a choice on wheels. If I could get all of that done before proving grounds (yeah right!) I would be extremely happy.
8.59 @ 158
mondale is offline   Reply With Quote
Old 12-12-2011   #13
^u better make a pass this year!
Old 12-12-2011   #14
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
Stroker kit, bigger cams, valvetrain, IM and TB.
Oh, and I'm trying to get it done by Tx2k12.
Old 12-12-2011   #15
^Take me with you!!
Old 12-12-2011   #16
b00sted_spyder
Megasquirt and bigger injectors to run e85 on the mr2. DSM gets more expensive parts.
Old 12-12-2011   #17
ylimert01
ylimert01's Avatar
Drives: Nissian
I am not sure on my mods yet on my new car! but I know I want to do the aux port mod, and update the nav and unlock the nav, fresh paint on the grill, paint the subaru badge, save for stage 2 parts/tune, and just enjoy it!
F Subarus!!!
-Emily
Old 12-12-2011   #18
^^Whats ur new car?
Old 12-12-2011   #19
Nothing.
Old 12-13-2011   #20
Why do I look at this shit?
