Old 01-26-2007   #1
Tman1gtsi
tubing
was wondering if anyone has a good idea or a hint of advice what I could use for vacuum hose, I am a bit short with a boost and air/fuel gauge, so all it does is light up ...thanks
-taylor
Tman1gtsi is offline   Reply With Quote
Old 01-26-2007   #2
Re: tubing
Doesn't it cost less than $1 per foot at every auto parts store?
Old 01-26-2007   #3
Re: tubing
You can get pretty colored tubing at roadraceengineering.com They have nice kits on their site.
Old 01-26-2007   #4
Re: tubing
How about vacuum hose? Go to the auto parts store.
Old 01-26-2007   #5
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: tubing
Hardware stores also carry it. ~$.50 per foot.
Old 01-26-2007   #6
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: tubing
Do you need the really thin nylon tube type or tubing the size of regular vacuum line? The hardware store probably won't carry the nylon tube type that is really thin.
7/25/09
Old 01-26-2007   #7
92EvilTalon
3.1L v6 power...
92EvilTalon's Avatar
Pit Stop Challenge Champion!
Re: tubing
talking about the white nylon shit that bends and brakes to easy? That same tubing that comes with the boost gauge. Go get some Vac lines from the auto parts store. Take in a sample of the size you want. And they will hook you up. You be alot happyer with the vac line over the nylon crap.
Josh LaCroix
Old 01-31-2007   #8
Tman1gtsi
Re: tubing
my apolgies for the late response, yes I will try auto parts store it's just that I need to add one to what I have for my boost gauge, still getting used to my car, but thank you very much for the advice, ill get back to you when I check around
Old 01-31-2007   #9
Re: tubing
So you need to extend your vacuum tubing? I had to do something similar to reduce the size on one end, they sell little plastic things to connect tubes if you absolutely have to go that route. But I'd just buy a new one to cover the entire length if I were you.
Old 01-31-2007   #10
xveganxcowboyx
Wanker
Drives: 95 M3
Re: tubing
Hardware stores do sell couplers that work pretty well, but I agree with slowboy. Just replace the whole length.
Old 02-01-2007   #11
Tman1gtsi
Re: tubing
ok sweet, ill check around, I actually am in duluth for school but have the car in Eagan, so im preparing to come revive it so ill look around and ill get back to everyone
Old 02-01-2007   #12
Re: tubing
Hmm, with this being said and all, how do most of you guys hook up your boost gauges? I run the white/clear nylon tubing all the way into the engine bay. And the I T it off the FPR vacuum line. But I have to use rubber vacuum hose on that T. So I've always just cut a small length of rubber hose, then just put some hairspray, or some sort of sticky adhesive on the outside of the clear tube, slid it into the rubber hose, and use a couple zipties on it. That's my ghetto coupler! I've used that method on all my cars because I guess I don't know a better way. What does everyone else do?
Old 02-01-2007   #13
Re: tubing
Plastic hose from gauge to engine bay. Slide very tight rubber tubing over plastic hose and then just plug it into the intake manifold port. I didnt use any zip ties, just found small enough rubber tubing to fit snugly onto the plastic hose. I used plastic tees if I needed to branch off to the wastegate or whatnot.
Old 02-01-2007   #14
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Re: tubing
Yeah I have always done it just like Brandon as well. I just use the nylon tubing totally. Thats the best way to go in my opinion. The intake manifold is probably the most accurate.
