Old 03-06-2005   #1
Hub - 2G GST
How much for a new:
front-left hub for 1998 GST Spyder FWD, CV shaft, and Rotor?
Thanks
Old 03-07-2005   #2
DSMPARTSGURU
Keeper of the lost toys!
Re: Hub - 2G GST
HEY guy....
hub and bearing assy $145.88 (in stk)
rotor $84.22 ( in stk)
CV AXLE W/ABS $284.59 (2-3 days)
hope this helps you out..
chris
CHRIS
Wayzata Nissan
Old 03-07-2005   #3
Re: Hub - 2G GST
How much for the CV without ABS? Or is it the same?
Old 03-07-2005   #4
DSMPARTSGURU
Re: Hub - 2G GST
WITH OUT ..... YOWSERS.... there are 2 options.
vin will determine wich one you will need.....
1st $255.06
2nd $316.78
once I get a vin I can be more certin on which one you will need.
chris
CHRIS
Wayzata Nissan
Old 03-07-2005   #5
Re: Hub - 2G GST
Or is there something else i could do? when getting the shaft out i damaged the threads where the castel nut goes. anything else i can buy? do you just sell that part? anyways the vin is 4A3AX55F3WE038227.
Old 03-08-2005   #6
DSMPARTSGURU
Re: Hub - 2G GST
Hey guy,
Your car uses the cheaper option so $255.06 plus tax.
mitsu for some reason doesnt offer that end? I dont know why.
honestly our shafts are expensive. most aftermarket parts store will be under $100.00
just as an option. If you are set on oe mitsu i can definetly get it for you.
chris
CHRIS
Wayzata Nissan
Old 03-08-2005   #7
Re: Hub - 2G GST
alright, thank you.
Old 03-08-2005   #8
DSMPARTSGURU
Re: Hub - 2G GST
im here to help.....
chris
CHRIS
Wayzata Nissan
