Old 03-01-2005   #1
Onefast99gsx
Question Need a Mitsubishi part #
Last night i was removing my front brake calipers so i could paint them. Passenger side came off just fine. The driver side bottom bolt came out fine but the top one was stuck terrible in there. It was completely loose but didn't come out so easy. Finally i got the top bolt out but the little rubber bushing/seal got destroyed. It was very corroded in there like moisture got in there.
I either need the complete top bolt or the little rubber seal that's towards the tip. I'm not sure if the top bolt is the Lock pin or guide pin.
Car: 1999 GSX
There is a Dodge dealer in town that still sells Mitsu parts but you better have your homework and part #'s before you go there. They're not too bright and their system is old.
Thank you!!!
