Old 10-23-2003   #1
Iwantboost
Guest
Tournaments Won: 6
Posts: n/a
Where would some of you recomend to bring my car to get the tranny replaced
Old 10-23-2003   #2
That is a very good question. If this is your only car, I would buy a dead tranny and ship it off to Shep to be rebuilt, then swap them or have someone swap them.
Old 10-23-2003   #3
If it were me, I would buy a dead tranny (Raptor had one for $100 out of a 91) and drop it off at ricks for a rebuild.
Old 10-24-2003   #4
^ im with him. DO NOT go to the dealer for a rebuild... others can do it MUCH cheaper. I got raped... that was 1 month before I knew about "other" people...
Just make sure you order some goodies for the rebuild.. unless you want it stock.
Old 10-24-2003   #5
Iwantboost
Guest
Tournaments Won: 6
Posts: n/a
Well i might be getting a GVR-4 and it has a hole in the bell housing so i dunno what to do.
Old 10-25-2003   #6
Iwantboost
Guest
Tournaments Won: 6
Posts: n/a
Well, i know this is asking a lot considering 90 % of you do not know me but ill give it a shot. I was wondering if any of you would be willing to help me switch trannys in a GVR-4 i might get and also how long does this procedure take
Old 10-25-2003   #7
v8klla
v8klla's Avatar
If it is any concilation to you, I went through the same problem recently in my GS-T...Hole in the bell housing. First, do you know why there is a hole? That could be a whole slew of problems!
Anyways, I did it myself with the help of some friends...Wasn't too bad, just time consuming. Getting it out is fairly straight forward, follow the shop manual.
As far as getting the tranny hole fixed that's another ball game. You need to take apart the tranny, which I also did. Nothing too complicated, just a lot of parts. I got mine welded at Lake Welding in Stillwater, he charges $65 an hour, which is what it cost me. I know Raptor on this site also welds aluminum you should have him do it for you...Not sure on his rates though.
Good Luck!!!
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 10-25-2003   #8
Iwantboost
Guest
Tournaments Won: 6
Posts: n/a
Is it more time consuming on an awd? and plus im not gonna get this fixed im gonna buy a new trany and have this one that i can fix incase something goes wrong w/ the new one
Old 10-25-2003   #9
1Fst14B
Ill sell yah a good messed up tranny for $500. Its mssing 4th gear, but only has double synchro second, gvr4 first, and some other things...i paid 1700 for TRE to rebuild it a year ago and its got only 3k miles on it...
Adam
Old 10-25-2003   #10
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
I looked at the trans with the hole and the hole is in the bell housing but something came from inside the trans and it wont hold any gear oil. The owner thinks the very tip of the halfshaft broke off and tore a hole in the trans. He says the clutch and gears are fine. So Tim, since there is a leak, you will need a new trans case and bell housing. But, there may be some other problems with the trans that you cant see until you get it all apart.
tsiawdspeed is offline   Reply With Quote
Old 10-26-2003   #11
v8klla
v8klla's Avatar
I'm betting good money that the front diff blew up in that one too...I couldn't tell anything was wrong except the fluid leak, that is until I took it apart and found the gear missing a tooth!
Chris
P: 763-545-3800
