View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 03-01-2010   #201
mike55112
mike55112's Avatar
Drives: 04 evo
Re: Dave's Evo X Build
NLTS can be a little tricky at first if you have never used it before,Kracka and schiedes witnessed my first attempt with it. But after some practice, its a very fun mod.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 03-01-2010   #202
mlomker
*Resting In Peace*
mlomker's Avatar
You keep the throttle at 100% when shifting and just push the clutch in quick, it really does make a world of difference.
Hmm. It must do ECU-based rev matching, then. It detects the pedal floored and when you touch the clutch it drops the revs enough to match up with the next gear.
Old 03-01-2010   #203
It drops the RPM's by a user-set amount. I personally have mine set at 1000. Clutch in at 7500, RPM's drop to 6500; clutch in at 4000, drop to 3000, etc.
Old 03-01-2010   #204
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Is that usually the standard amount 1000? Thats what mine was too.
t-revzr is offline   Reply With Quote
Old 03-01-2010   #205
I believe 800 is the default, but I generally set it to 1,000 on any car I install Tephra on. It really doesn't matter much since the actual RPM drop is ~1,500 (varies depending on gear of course); you'll only notice if you're a slow shifter. The only time I actually bounce off the limiter is doing a NLTS into 5th gear; I baby 5th so I don't get the common grind so so many people have developed.
Old 03-07-2010   #206
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Well my car goes through 1-4 gears beautifully.
However, last night doing a fifth gear pull (freeway passing)the clutch basically opened up completely, meaning slipped horribly.
It slipped and bounced all the way off the rev limiter. I let it cool down and its back to normal but the new clutch will coming soon now. I was thinking about doing a few things before it because it was holding up great. However I don't want to have to think about it anymore. So new clutch will be coming.
Old 03-08-2010   #207
Haha I knew it wouldn't last very long.
Old 03-09-2010   #208
Murlo26
Murlo26's Avatar
1 week wasn't bad
Update, clutch wouldn't even fully hold 3rd gear on the entrance ramp today
NOw it's getting not fun to drive...going to order my ACT 6 puck very soon I am thinking. Maybe today.
Old 03-09-2010   #209
wut? passing on the freeway w/o downshifting? zzomg!
Old 03-09-2010   #210
Murlo26
Murlo26's Avatar
No need to now, well there wasn't. Enough power in fifth to pass. When you are going 80 already, the gearing on the X is such that you are already building boost. So fifth gets used a lot for passing, at least for me.
Old 03-09-2010   #211
mlomker
*Resting In Peace*
mlomker's Avatar
Passing? I'm always in the right lane.
I hate 5th gear...at 45ish it is at a lugging rpm range.
Old 03-09-2010   #212
Haha with my DSM I never downshifted from 5th to pass. 16g FTW!
Old 03-09-2010   #213
Constant_Project21
Constant_Project21's Avatar
Drives: E36
This. 16g FTW indeed.
Old 03-09-2010   #214
Murlo26
Murlo26's Avatar
evox gearing ftw i guess since you are always above 3krpm.
However mpg ftl
Old 03-09-2010   #215
Get the Shep final drive.
http://www.sheptrans.com/transmissio...tm#final_drive
Old 03-09-2010   #216
Murlo26
Murlo26's Avatar
tempting, but awfully expensive.
Old 03-09-2010   #217
Yeah, that would be a part I would wait for the price to drop on, I can see that thing being about $3-400 in about 2 years
Old 03-09-2010   #218
Murlo26
Murlo26's Avatar
Id rather invest more in my head or even drop ins, rods/pistons, and rev the car out to 8500-9000rpms. Then get taller tires if need be. That way I wouldn't need this.
Old 03-09-2010   #219
mlomker
*Resting In Peace*
mlomker's Avatar
I plan to Shep my drive train if/when I manage to toast the six puck.
Old 03-12-2010   #220
Murlo26
Murlo26's Avatar
New ACT clutch/flywheel are in at DB (at least I am pretty sure they are, Shane said yesterday or today).
I ordered some new Mits spark plugs, mine looked pretty old when Shane checked them.
I also just ordered the DOM2 wga, its a 20psi one. It seems to hold boost way better, so maybe I can erk out some more power.
Here is a red before and after boost plot using the dom2 actuator.
Very similar to mine, tapers to 26psi ish.
Now with dom2 actuator.
If you look at the new graph, you can see he hits peak power at lot sooner and it won't go up because he has exhaust restriction, he is still on a stock unmodified manifold and 2.75" exhaust. So if he opened that up he would've made quite a bit more power.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
