Old 02-01-2005   #11
john
Business as usual
john's Avatar
Re: problem
Originally Posted by LightningGSX
I believe you can, but the pulses will be inverted.It would let you know if thats the problem though.I'm about 95% sure its your CAS or the CAS's wiring.The easiest thing to do would be to take a multimeter, set it to AC, put the positive lead on the RPM wire of the AFC(or the CAS wire), ground the negative lead and check for voltage during cranking.
No voltage would mean that the CAS is not functioning right? All the testing is doing is checking for any voltage correct. Then I can use one of my gay voltage testers instead of getting a new battery for the miltimeter.
97 Viper GTS
