Old 10-14-2004   #9
520Talon
Are you putting in a cage or a bar? A cage follows the a pillars and has a winshield bar. A six point bar is a d-ring with four post off it to keep it from going forward or backward. Is it a bar or a cage? A cage will definately be near your head and side. A roll bar will pass by your side.
The good stuff is only half sided because, well if your are going to be hitting the other side of the bar than the side where your head would normally hit, you are in more trouble than padding is going to save you from anyway.
If the bars won't be at your head but at your side all you need is the soft foamy stuff.
