Old 11-08-2008   #2
v8klla
v8klla's Avatar
Re: MAPerformance Year End Clearance Sale / Pricing at or below cost on most items!
KOY R2024 Koyo Aluminum Radiator / 2g DSM 1.00
KYB 334470 KYB OE Replacement GR-2 Excel-G Right Side Strut 04-05 Subaru WRX-STi / 05-06 Impreza(Exc Outback) 1.00
KYB 334471 KYB OE Replacement GR-2 Excel-G Left Side Strut 04-05 Subaru WRX-STi / 05-06 Impreza(Exc Outback) 1.00
KYB 73403X KYB AGX Adjustable Shocks / Struts (Complete Set for '02-'03 WRX) 2.00
MAF 050DSMTRANS1G MAFT / 1g DSM 1.00
MAH EVO367366I13 Mitsubishi 2.0L 93-02 Eclipse 1.00
MAH EVO367385I13 Mitsubishi 2.0L 93-02 Eclipse 1.00
MAH MIT367366I13 Mitsubishi 2.0L 88-92 Eclipse 21m 1.00
MAH WRX209917I22 Subaru EJ 25, 99.5 mm Bore 8.5/1 Comp 2.00
MAH WRX209937I22 STi, Legacy GTI 100mm Bore 8.5/1 Comp 1.00
MAP 23SB-S1 MAP 6 Bolt 2.3l Shortblock / Stage 1 (Wiseco / Eagle) 1.00
MAP 23SB-S2 MAP Stage 2 2.3l Shortblock / *See Invoice #1682 for included items 1.00
MGN 45423 Magnecor Competition Spark Plug Set Evo 5-8 1.00
MIC 3010 Mickey Thompson ET Drag Tire / 22x8x13 4.00
MIC 3019 Mickey Thompson ET Drag Tire / 22x8x15 4.00
MSD 5900 MSD Blaster Ignition 1.00
OEM 6B24C-.5 OEM 6 Bolt 2.4l Crankshaft / .5mm Undersize 2.00
OEM 7B20C OEM 7 Bolt 2.0l Crankshaft / Standard 2.00
PE TH650F Power Enterprise Top Feed 650cc Fuel Injectors 4.00
PER ASM-INT-600BK Blow Off Valve Kit Recirc EVO VIII/IX - BLACK 1.00
PER ASM-INT-720 Perrin Performance Electronic Boost Control Solenoid 1.00
PER PEP-BDY-105 Perrin Performance Shorty Antenna 2" Evo VIII/IX 1.00
PER PEP-EXT-200 Perrin Performance SS Downpipe / 3" / Evo 4.00
PER PEP-EXT-300BK Perrin Performance Catback Exhaust / Stealth / Evo 1.00
PER PEP-SUS-210 Perrin Performance Adjustable Endlinks / Rear / Evo 1.00
PER PSP-BRK-400 Master Cylinder Support Brace 02-07 Impreza 2.00
PER PSP-ENG-500BK Perrin Performance Radiator Shroud / WRX & STi / Black 1.00
PER PSP-EXT-206F Perrin Performance Downpipe / Front Section / '06-'07 WRX 1.00
PER PSP-EXT-206R Perrin Performance Downpipe / Rear Section / '06-'07 WRX 1.00
PER PSP-EXT-305BK Perrin Performance Sport Tone Exhaust / Single Tip / Stealth / WRX & STi 2.00
PER PSP-INT-200BK Short Ram Intake System WRX 2002+ / BLACK 2.00
PER PSP-INT-200BL Short Ram Intake System WRX 2002+ / BLUE 2.00
PER PSP-INT-200RD Short Ram Intake System WRX 2002+ / RED 1.00
PER PSP-INT-600BK Perrin Performance Recirculating Blow Off Valve / Black / WRX & STi 1.00
PER PSP-INT-600SS Perrin Performance Recirculating Blow Off Valve / Red / WRX & STi 1.00
PER PSP-SUS-100 Perrin Performance Front Swaybar / 22mm / WRX & STi 1.00
PER PSP-SUS-101 Perrin SWAY BAR FRONT 25MM (1") 02-07 WRX/STI 1.00
PER PSP-SUS-200 Perrin Performance Sway Bar / 22mm / Adjustable / WRX 1.00
PER PSP-SUS-205 Perrin Performance Sway Bar / 22mm / Rear / STi 1.00
PER PSP-SUS-207 Perrin Performance Sway Bar / 25mm / Rear / STi 1.00
PER PSP-SUS-208 Rear Sway Bar 25mm (1") Bar STi 4.00
PER PSP-SUS-210 Perrin Performance Rear Endlinks / 93-07 Impreza & WRX 2.00
PER PSP-SUS-215 Perrin Performance Endlinks / Rear / STi 1.00
PER PSP-SUS-400 Perrin Performance PSRS / WRX 2.00
POW 518PSL/R Powerslot Rotors / Up to 5/92 AWD DSM Front Pair 1.00
POW 583PSL/R Powerslot Rotors / 6/92+ AWD DSM Front Pair 4.00
POW 735PSL/R Powerslot Rotors / '04 STi Front Pair 1.00
POW 736PSL/R Powerslot Rotors / '04 STi Rear Pair 1.00
POW 772PSL/R Powerslot Rotors / 2g Rear Pair 3.00
PRT 13-1901-BL Prothane Motor Mounts (Black) 95-99 DSM 6.00
PRT 13-1902-BL Prothane Motor Mounts 90-94 DSM (BLACK) 3.00
PTE 071-1026 PTE 3" V-Band Clamp 2.00
PUN T35BSS Punishment Racing SS 5 Bolt T3 O2 Housing for DSM 1.00
SAM TB1524-RED Samco Sport VW Golf Mk4 / Beetle / Audi TT 180 / Seat Leon / Skoda Octavia Turbo Induction (Red) 1.00
SAM TB997-BLU Samco Sport Turbo Inlet Hose (WRX/STi) / Blue 1.00
SAM TCS209-BLU Subaru Impreza STi 01/02 (4) Turbo 1.00
SAM TCS271C-RED Samco Sport Coolant Hose Kit / SRT-4 / Red 1.00
SBR 0037 Slowboy Racing 2G DSM High Temp Manifold Spacer / Heat Barrier 1.00
SCA 65138289 Scat Pro 4340 Forged H-Beam Connecting Rods / Subaru WRX EJ20 1.00
SKU 305-06-0240 Skunk2 264/272 Camshafts / Evo 8 1.00
SKU 307-05-0290 Skunk2 Intake Manifold / 1992-93 Integra GS-R 1.00
SKU 311-06-0390 Skunk2 Dual Valve Springs & Retainers / 4g63 1.00
SPC 81250 SPC EZ CAM XR (12MM) 1.00
SPC 81260 SPC EZ CAM XR (14MM) 1.00
SYN SB001.4A Synapse HKS-style billet Aluminum flange for SB001 BOV 1.00
SYN SB001.5A Synapse Anti-stall valve kit for MAF cars with atmospheric discharge in billet Aluminum 1.00
SYN SB001.6A Synapse Synchronic BOV TiAL 50mm Adapter Flange in billet Aluminum 1.00
SYN SB001.8A Synapse Synchronic BOV SB001 Volkswagen, Audi 1" hose end adapter fittings only in Aluminum (2 p... 1.00
SYN WG001B.1 Synapse 40mm Universal 2-Bolt Synchronic Wastegate 1.00
TAY 98069 10.4mm Thunder Volt 50 Wires - DSM 1.00
TOK BU3532 Tokico Illumina Series Shocks for 2G AWD (Set of 2) (Front) 1.00
TOK BU3532-1 Tokico Illumina Series Shocks for 2G AWD (Single) (Front) 1.00
TOK BU3533- Tokico Illumina Series Shocks for 2G AWD (Set of 2) (Rear) 1.00
TOP CBSMI4 Topline Complete Block Gasket Set / 6 Bolt DSM 2.00
TOP CGSMI23 Topline Complete Gasket Set / 1g 7 Bolt DSM 3.00
TOP EPSMI4 Topline Freeze Plug Set(Nine 35mm Plugs / DSM 1.00
TOP HSMI23 Topline Head Gasket Set / 1g 7 Bolt DSM 1.00
TOP HSMI6 Topline Head Gasket Set / 6 Bolt DSM 3.00
TOP PAMI6T Topline Pistons with Rings Set / Standard Bore / 6 Bolt DSM 1.00
TOP WPMI23 Topline Water Pump / 1g 7 Bolt DSM 2.00
TUR FG-BOV-WRXSS Blowoff Valve Supersonic - Subaru WRX 01-05 1.00
TUR TS-0501-1011 Turbosmart 38mm Ultragate / Sleeper Black / 7psi Spring 7.00
TXS EVO8-FMIC TurboXS Front Mount Intercooler / Evo 1.00
TXS EVO8-FP TurboXS Downpipe / Evo 2.00
TXS WS08-RFL Turbo XS 2008 WRX RFL BOV 1.00
TXS WS-INTAKE TurboXS Short Ram Intake / WRX & STi 3.00
TXS WS-SBE TurboXS Stealth Back Exhaust System / WRX & STi 1.00
TXS WS-TBE TurboXS Turbo Back Exhaust System with Cat and Standard Muffler / WRX & STi 1.00
VIB 1636 Vibrant StreetPower Catback Exhaust / WRX & STi 1.00
VIB 18121 Vibrant Strut Tower Brace / 1g DSM / Polished 1.00
VIB 2178 Vibrant 2.5" O.D. Aluminum 90 Degree Bend - Polished 1.00
VIB 2744 4 Ply Re-Inforced Silicone Elbow Connector - 3" dia. - 90 deg. Elbow (BLACK) 1.00
VIB 2772 Vibrant Performance 4 Ply Reducer Coupling, 2.5" x 3" x 3" long - Black 1.00
VIB 2793 Vibrant Stainless Steel T-Bolt Clamps (Pack of 2) / Clamp Range: 2.66"-2.97" / Designed for 2.5"... 1.00
VIB 2794 Vibrant T-Bolt Clamp / For use with 2.75" couplers 1.00
VIB 2795 Vibrant Stainless Steel T-Bolt Clamps (Pack of 2) / Clamp Range: 3.28"-3.59" / Designed for 3" C... 2.00
VIS 7022 Visteon Aluminum Radiator w/Spal Fan / 2g N/T DSM 2.00
WHI KSR206 Whiteline Steering Rack Bushing Kit 1.00
WIL 150-9764K Wilwood PolyMatrix E Compound Brake Pads / Dynalite Single Front Axle 1.00
ZEX 82021 Zex Wet Nitrous System with 10lb Bottle / 55,65,75hp Jets Included 4.00
ZEX 82023P Zex Wet Nitrous System / Polished Bottle / 75,100,125hp Jets Included 1.00
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
