10-10-2009
#101
Re: The Black Beast
Originally Posted by TkrPerformance
good to see dad and you got it all back together. I head from dad there was some problems with it oing together
Yeah, there was a broken off stud in the outlet side of the turbine housing that was more difficult to get off than we thought it would be, so we had to drill it out then clean up the threads with a tap. Whoever clocked the compressor housing last time didn't grind off all of the little locater pin so we had to get that out the rest of the way. Also there were some messed up threads in the outlet of the compressor housing, so we had to clean out those threads. Also, the oil feed fitting wouldn't get tight, so we had to use some red loctite to get that to tighten up. Then just as we were finishing it up on Thursday night, the compressor housing popped off because we didn't have it on the backing plate far enough to get the snap ring in the groove all the way.
So it was way more of a pain in the ass than I thought it would be, but it went back together pretty easily on Friday morning. Ken had it all back together by the time I got there at 1, and nothing leaks so I'm happy. Now I just gotta get that coupler so I can put my intake and filter back on.
10-11-2009
#102
Re: The Black Beast
37psi spike to 27-28psi by redline here. hit 40psi a couple times.
Originally Posted by goodhart
On a 16g?
Yes on a 16g. Mine will hold 30psi on the stock wastegate just on the spring pressuare,but that is a modded ralliart gate
40 psi on a 16g? Am I reading that right? I'm sorry I guess I've just never heard of a 16g that can actually run that much boost.
Originally Posted by scheides
10-11-2009
#103
is Nashty
Drives: Cyborg from Japan
Re: The Black Beast
Looks like a few mitsustyle guys need to read up on the 16g's! Haha. Lately since E85 has become big alot of people have been pushing 16's waay past what would seem to be their limit and put down some good numbers with it.
-1990 Mitsubishi Cyborg 4WD-
10-11-2009
#104
Re: The Black Beast
^^ Exactly why I switched to it. I figured with my cams, intake manifold and external wastegate, I should be able to hold boost better in the upper RPM ranges. So far it's rock solid at 20 psi to redline. I don't really wanna go much higher than that til I get tuned on e-85 though, since every now and then I'll get a little knock in 3rd gear. I really need to get a damn laptop... haha
That, and it's much easier to drive around town now. If I wanna go around someone quickly, I don't need to downshift since I can hit 20 psi in 5th gear at about 3300 rpm, which puts me at about 70 mph and pulling hard. Judging by the butt dyno, it feels like it's pulling about 90% as hard as the 3076 was, but now it just starts at a lower rpm. The only thing I miss about that turbo is the way it sounded when it spooled up. haha
10-11-2009
#105
Re: The Black Beast
anti-surge covers do indeed make lovely sounds
10-11-2009
#106
Re: The Black Beast
40psi is just waaaay past the efficiency range of a turbo that small, you would just be blowing hot air at that boost level even with E85. A fellow style member's car was up to 31 or so on the dyno and the higher we went the less power we made so we ended up going back down to 29psi because the turbo was simply out of breath.
Also according to this website, the highest boost any of these guys were running on a 16g was 31.5 psi
http://dsmtimes.org/times.php?Header...rbo_16g&Page=1
If someone here is running 40psi on a 16g, I want to see the setup because that would be a hell of a feat!
10-11-2009
#107
is Nashty
Re: The Black Beast
On dsmtalk there was these guys running 40psi on their 16g with E85 and put down 499whp. That's the most power to date with the 16g. You can do some research yourself to get more creditable facts instead of me just telling you if you'd like. There is also english racing who ran meth/E85 with NO intercooler running 30psi to redline with no issues.
10-11-2009
#108
Re: The Black Beast
You got any links to these people's setups? I'd like to see them.
10-11-2009
#109
is Nashty
Re: The Black Beast
I don't have them saved no. But there are alot of threads on Talk about high boost with 16g's. They get very in depth also I believe. Been a little while since I've read any of them.
10-12-2009
#110
Re: The Black Beast
Kevin I have an old laptop that I am getting rid of if you need soemthing for tuning.
I only spiked 40psi and couple times usually in 4th.
10-12-2009
#111
Drives: FS-T
Re: The Black Beast
Not to be rude, but you guys should probably move your conversation / thread jack into private messages.
Hence this is a project thread in the project section, not a 16g thread in the forced induction section...
10-12-2009
#112
wants to kick mark
Drives: Battery with wheels
Re: The Black Beast
you could come and load the program onto my computer and go make some runs if you would like.
10-12-2009
#113
Re: The Black Beast
Kevin, do you need the 4" - 2.5" (or whatever) coupler for the FP 4" intake? I have one if you want it. Buy me some beers on the cruise.
10-12-2009
#114
Re: The Black Beast
Oh sure, now you offer... I just ordered one from FP since I couldn't get ahold of Brownman's wife to get his. If i can cancel my order, I'll take you up on that.
10-13-2009
#116
Re: The Black Beast
She got home late last night flight was delayed.
