Old 10-28-2004   #1
DeAdGnRaTiOn
Send a message via AIM to DeAdGnRaTiOn Send a message via MSN to DeAdGnRaTiOn
Alright dudes, I installed my manual boost controller, which I think is correctly but this is why I am starting this topic. I also recently installed an after market boost gauge so i can get some accurate readings. When I run with no MBC I am hitting 10psi on the guage...which I assume is normal. When I install my MBC it will hit up to 15, then slowly drop to 10 and stay at ten till i shift, then it will repeat...reach up to 15, slowly drop to 10. I can unscrew the MBC completly or screw it in and it will make no difference. I will always hit 15 and it will slowly drop as long as the MBC is in. When it is out...steady 10. WTF is the problem lol. 1990 Talon AWD Tsi.
I tried unplugging the sensor on the stock boost controller and I have just filled up with 92 octane. I heard that could be a problem...but still no dice.
DeAdGnRaTiOn is offline   Reply With Quote
Old 10-28-2004   #2
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
Does your car have aftermarket exhaust? Could be boost creep... or there may be a boost leak between the MBC and the wastegate.
Old 10-28-2004   #3
DeAdGnRaTiOn
stock exhaust but i suppose that wastegate problem could make sense. The hose that is on there is snug, but not as tight as the stock one. Is there alot of pressure going through there?
Old 10-28-2004   #4
Boost creep is when the boost goes up not down. And a leak between the MBC and wastegate would make more boost. A bleeder style boost controller is essentially a leak.
Check for boost leaks in system from the turbo to the head. You should really do an exhaust before you turn the boost up though.
Old 10-28-2004   #5
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Make sure the hoses aren't switched around. Mine was doing the same thing except spiking to 17 then falling to 10. It had been so long since I hooked one up I accidentally reversed the flow lol.
Old 10-28-2004   #6
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
And we have a winner. Sounds to me like you hooked it up wrong also.
CRAIG
Old 10-28-2004   #7
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
But if it was hooked up backwards wouldn't it just keep boosting until the motor popped? Unless he has a really bad boost leak. I have done this once and got to 30psi (where my gauge maxes), then the line blew off and I noticed I was running uber-lean, then backed off. Luckily I didn't kill anything.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 10-29-2004   #8
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Originally posted by Alpine TSi@Oct 28 2004, 10:01 PM
But if it was hooked up backwards wouldn't it just keep boosting until the motor popped?Â* Unless he has a really bad boost leak.Â* I have done this once and got to 30psi
He said he was running stock exhaust and mine was a 14b w/ stock exaust. Were you running a bigger setup?
Anyways, listen to the MBC and see if it makes a hissing noise. There was air coming out of the bleeder hole at idle. Something to check out. :goodluck:
Old 10-30-2004   #9
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
Slightly bigger yes. 16G, 2.5 inch dp and 3 inch catback. Are you trying to say that is all the boost it will build like that?
320awhp/320lb-ft tq
12.772 @ 108.57
678/1000
Old 10-30-2004   #10
DeAdGnRaTiOn
Hey I will try that and see what happens. Thanks alot dudes!
Old 10-31-2004   #11
DeAdGnRaTiOn
That was it. Thanks alot guys!!
Old 11-02-2004   #12
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
No problem man, glad we could help
Old 11-02-2004   #13
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Now that you've got that problem taken care of...it's my turn...haha. Since this is already a thread for what I had to ask.
I'm still having spiking problems. I bought Mike's (from QPR) MBC and he said that it takes some tuning to get it fully adjusted. But I cant think of anything else to try to make it work right. There is only two screws to play around with, so there isnt many ways I can adjust it. I've pre-setted it and it runs like 14 lbs with spikes up to 17. I adjusted it a little and that didnt help the boost spike. So is there anything else I could try to fix, so it doesnt spike. I have the TurboXS HPBC. I've been having this problem for so long, I forgot how nice it is to have the boost just jump up to the setting and stay there...I miss those days...haha.
Just incase, this is what I have done:
2.5" dp+testpipe...2.25" testpipe back exh...2.5" exh....air filter...MCB...boost+air/fuel gauge. I also have a whole in my dp if that might be the problem?
Old 11-13-2004   #14
93talon
Send a message via ICQ to 93talon
the downpipe is after the turbo so that would have nutin to do with it
93talon is offline   Reply With Quote
Old 11-16-2004   #15
1slowdsm
1slowdsm's Avatar
I guess I'll try to having the bleeder fully closed and the ball&spring screw all the way out. Hopefully that'll do something different so I can atleast have a clue on whats going on.
