Old 03-27-2015   #961
Re: House Projects
Dayyum! Had no idea it was that big !
Old 03-27-2015   #962
Re: House Projects
I had a floor, kitchen, and bathroom guy out last night. Very nice guy, appears to do quality work...basically a side business for him in addition to his firefighter job. He's going to get started next week by replacing some cracked floor tiles in my kitchen, do a few more odds & ends (sinks, faucets, vanity, etc.), then get started on a master bathroom refresh for me within a few weeks once he gets a few custom pieces ordered.
I'm toying with the idea of selling vs. staying once my list of updates is done. I've been eyeing up some new construction, but I'm not sure if I want the additional commute (my current 7-mile is pretty nice!). I think I'll hold off on a final decision until my current projects are done to see how they turn out, and if I'm happy with them.
Old 03-27-2015   #963
Re: House Projects
Awww, that's what all the pretty ladies say
Old 03-27-2015   #964
Re: House Projects
Spaz looks like the matrix.
Old 04-02-2015   #965
Re: House Projects
So starting april we will be breaking ground on our new deck.
Last fall i tore out the existing structure to hopefully get the footings dug and filled and inspected. But due to weather it didnt work out.
We are creating a deck that will wrap around the back of the house that will be much bigger.
Looking at a number of different woods for the decking material. Ipe vs Tigerwood vs Cumaru, The latter two being less expensive but still pretty hard on the hardness scale and will hold up for 25+ years. Tigerwood looks awesome and cumaru has more of a reddish tone to it which i like as well.
Anyways ill try to keep updating on progress of this.
The Contractor i am using is DunRight Remodeling. (http://Dunrightremodeling.com)
ID:	15108   Click image for larger version
Old 04-08-2015   #966
jeremy1375
jeremy1375's Avatar
Re: House Projects
Last year I had a 40x60 pole building built to have a place to work on all my projects. I had the floor poured and then I installed the electrical panel and meter socket as well last year. Xcel energy hooked up the power in late fall and then it sat over the winter.
This year I've begun coating the floor with epoxy. I decided to go with white coated with clear to brighten it up and make it easy to find small parts that get dropped.
To make the coating as even as possible, I'm coating each 10x10 area that is separated by relief cuts separately. Once the white is all applied and cured the whole floor will be gone over with an abrasive pad to prep it for the clear coat.
Once the floor is finished I'll begin sealing all the leaks up in the walls and roof. I watched where the building let in snow in the winter and rain in the spring so I'll deal with those and then begin electrical and finishing and insulating the interior. My hope is to get it completed this year.
ID:	15135   Click image for larger version
ID:	15136   Click image for larger version
Nothing is exactly as it seems, nor is it otherwise.
Old 04-08-2015   #967
Re: House Projects
^That's awesome!
Old 04-09-2015   #968
Re: House Projects
Dude, you need to spray foam that building. It will water proof it, seal all air leaks and give you good insulation. Winning all around. Big shops FTW!
Old 04-09-2015   #969
Mark Leasure
Mark Leasure's Avatar
Re: House Projects
Unreal poll building! Super awesome, I would love to have a little more land and the ability to build a super sized shop. Nice work.
www.maperformance.com
Old 04-09-2015   #970
Re: House Projects
Pics not working?
Old 04-09-2015   #971
jeremy1375
jeremy1375's Avatar
Re: House Projects
Pics not working?
They're still working as far as I can tell. Maybe the host is blocked by the isp you're using?
Old 04-09-2015   #972
jeremy1375
jeremy1375's Avatar
Re: House Projects
I'd love to be able to foam insulate the whole thing and be done with it. I got a quote for it last year and it was something like $16k to do the whole thing. No room in the budget for that. I'm leaning towards blowing dense pack cellulose in the walls and loose fill in the attic. That'll leave room in the budget for other things. A 2 post car lift being the thing I'm most looking forward to. I'm getting too old for the jack stands to be fun anymore...
Old 04-09-2015   #973
jeremy1375
jeremy1375's Avatar
Re: House Projects
Thanks! If you ever do decide to buy property to build one on, make sure to check the zoning first. I thought I was good to go living in Lindstrom with farm land all over. It turned out my zoning only allowed the building to be 2000 sq ft minus the garage size. I spent the summer of 2013 working with the county to rezone the whole north side of my street instead of putting up the building.
Old 04-10-2015   #974
Re: House Projects
yeah our company put in some filtering, probably that.
boo
Old 04-10-2015   #975
jeremy1375
jeremy1375's Avatar
Re: House Projects
^ I added them as an attachment.
Old 04-10-2015   #976
curt_gendron
curt_gendron's Avatar
Re: House Projects
The pole shed looks great! I built a 40x80 shed with our new house in 2013, but other than adding some lights and garage door openers, I haven't done much with it. I like the epoxy coating and I'll need to insulate it eventually. Add some more pics when you are done with each phase.
later,
Curt
Minnesota 3/S
Old 04-12-2015   #977
jeremy1375
jeremy1375's Avatar
Re: House Projects
^ I plan to keep the pics updated as work progresses.
I'm curious if you have any issues with leaks in yours and if any steps were taken to seal things up when yours was built. I used great stuff foam to seal up the bottom of my building where the siding ribs meet the flashing on the grade board. I've realized that there are multiple leaks that drained out that area. Now they drain out on to the floor.
I have to go through and seal all the siding joints now.
Old 04-13-2015   #978
curt_gendron
Re: House Projects
Mine has stayed pretty dry. Half of my shed is a dirt floor. We use it for dog agility. So some of the dirt is a little wet because the dirt on the outside is wet. Kind of a sponge effect. But the half of it that is concrete stays dry.
Minnesota 3/S
Old 04-14-2015   #979
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: House Projects
I just found out I am getting a decent sized "relocation" check from my work for moving to fargo. I will be doing quite a few small items around my house to clean it up to get ready to list it. I don't think it will be anything major but if I do I will post something up.
Sad that I just built a great new deck and won't get to really use it
Oh, if anyone is looking for a house in blaine or knows anyone that would be interested please let me know. I will toss someone a finder fee if they buy
Old 04-14-2015   #980
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: House Projects
Do you mind sharing what it cost for the initial structure, concrete pour, etc? I have been considering the same thing in the near future and I literally have no clue what that sort of thing costs.
Style's automotive engineer
