Old 07-28-2014   #41
SlowWhite
Been there, done that.
SlowWhite's Avatar
Well first real test for the new radiator and now enclosed stock fan.
Temps outside were saying 101 at the bank. Car ran mostly at 196-200 thr whole way to work with momentary temps at 193 as well as 203.
When I pulled into the parking lot at work after all the speed bumps when I finally parked temps showed 210 i sat with the car idling for two minites to see if they go up but sat at 210.
Any rate for the outside temp im happy with what I was seeing. Normally anything over 95 outsode car would always sit at 216-229.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
Old 07-28-2014   #42
Id take that on a 100* day, sounds like its working fairly well, good job. I think in link you can adjust the temp the fans kick on on 2Gs as well if you wanted, but either way those temps seem decent as is.
Old 07-28-2014   #43
SlowWhite
SlowWhite's Avatar
Sorry I should have posted it earlier but since just before my first coolant flush/change I have had the fan running at all times via link.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 07-29-2014   #44
No reason to let the fan run all the time. Glad to hear your temps have become more stable!
Old 07-29-2014   #45
At high speed, would a fan that is on acutally be a hinderance to air just trying to flow right through?
Old 07-29-2014   #46
It shouldn't be, if anything, high pressure air might push the fan speed higher. I can't see it being a restriction.
Old 07-30-2014   #47
SlowWhite
SlowWhite's Avatar
Arrow Re: 1997 GSX - DD, RR, and 11's.
Well did a test today on my way into work.
1st half of my 22mile trip I turned my fans so they run normally when needed. Temps stayed at 210.
At the half way point switched the fans to always on. And temps immediately dropped to 193 and stayed there the whole trip till I hit the parking lot where they went up to 203.
Outside temps said 95 today just for comparison
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 07-30-2014   #48
SlowWhite
SlowWhite's Avatar
Also had my first roll race. I was stuck behind a car doing 45 in a 75-85mph and I saw a white 300 coming up in the rear view. (There are only 4 passing zones the entire trip)
So my first chance I passed and the 300 immediately passed as well amd then tail gated the he'll out of me. Hes slow down then speed up on his third time. I accelerated amd he tried to stay with me
Input about 4 cars on him before letting off somewhere in the top of 4th.
The next passing zone he pulls up next to me give me the thumbs up amd then.continues to pass me.
On the back of his car it said Hemi, and he had some kind of aftermarket exhausts it wasn loud
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 08-10-2014   #49
SlowWhite
SlowWhite's Avatar
Well today got back from VIR chump race early so decided to clean my fuel filter and swap out my isc and tps sensors.
For starters first thing I noticed after taking the I/C piping off was my positive wire from the battery (relocated to the back) and I always wondered if maybe there was a loose connection. And its all hooked up to the starter and I was easily able to move the wires back and forth. I tried tightening them but they still moved. After putting on a washer and a locking washer I tried again. They tightened only I then noticed its not the wires moving but the piece they are attached to? Any idea why it swivels? I believe that is the voltage regulator its attached to. (Small round cylinder looking thing)
I attempted the free fiav mod but after taking it all apart it haf already been done. Any ill effects from going with a block off plate? (It 2) would be just to clean up the engine bay a bit)
Next I swapped out the tps sensor and noticed that the one on the car only had 3 prongs. The new one j has 4. The plug has 4 wires so I went ahead and swapped the sensor.
After that I did the isc. The old one was just filthy and when you moved it. It was easily turned.
The new one feels like it has more tension on it.
Went for a quick drive to get gas and should have done a boost leak test but forgot. Will do that tomorrow before work.
The new isc started out reading high (2turns out from close it was reading 86%)
But idled great and bov would close perfectly after rev by hand...old one read 36 when o t was set that way) any rate after the drive to the gas station isc was reading 44 when idling)
however tps even after doing the tps adjust on link. 0-100% it was still fluctuating between 0-1% at idle and when it would go to 1% idle would be high so tomorrow will be back at it. And Will be doing my BLT.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 08-10-2014   #50
The fiav I usually block off, but keep the ISC for sure if you want to retain a decent idle.
Old 08-14-2014   #51
SlowWhite
SlowWhite's Avatar
Well little more work done to the car today. The windshield wipers were getting rusty from all the rain we've had this month (seems like every day for the past month)
I took a wire brush and took all the rust /paint all the way down to the metal, and then painted first with flat black rustoleum. Looked a little to dull for me so I then used gloss black rustoleum. They are still drying in my garage so I haven't seen the final product as I had to leave for work. I also painted the little caps as well. As the previous owner had gotten red on them by accident so they looked bad.
ID:	14669   Click image for larger version
ID:	14670   Click image for larger version
ID:	14672   Click image for larger version
ID:	14673   Click image for larger version
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 08-15-2014   #52
Nice progress! I repainted my 1G wiper arms too, really made the car look better. I also repainted the plastic trim underneath the wipers.
Old 08-15-2014   #53
SlowWhite
SlowWhite's Avatar
that will probably be next as he spilled red paint on it also when he painted the car. Hopefully tomorrow or Sunday if the weather holds.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 08-15-2014   #54
FYi any time you spray bare metal you should use an acid etch primer to prevent rust in the future. Rustoleum has it in cans.
Old 08-19-2014   #55
SlowWhite
SlowWhite's Avatar
well went back and painted the wiper cowling using the same "gloss black as the wiper arms".
Like posted above, it was sun faded, and had red paint spilled on it by previous owner... turned out great now i just need to get new wiper blades as they are faded and now stand out.
ID:	14676   Click image for larger version
ID:	14677   Click image for larger version
ID:	14679   Click image for larger version
ID:	14680   Click image for larger version
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 08-19-2014   #56
SlowWhite
SlowWhite's Avatar
its funny for being a $25/gallon rustoleum painted car it sure does shine in the pictures and that was before I washed it lol.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 08-19-2014   #57
Wipers and cowl look good, really cleans up the look. How are the sills along the windows? If they faded/cracking, you can get new ones for pretty cheap from the dealership.
Old 08-19-2014   #58
Looks good.
Old 08-19-2014   #59
SlowWhite
SlowWhite's Avatar
pretty much all of the rubber is cracked or in rough shape. When I have the car painted come tax returns, I plan to have all the rubber, etc replaced.
I've also fixed or bought all the missing interior plastic pieces already, I just need a new passengerside airbag, and then leather seats.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Old 08-19-2014   #60
I think I only paid around $40 for the pair of new window sills from the dealership.
