Old 02-26-2013   #421
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Mark's 1G Winter Projects
Man that engine bay is purdy.
That's an understatement! Cleaner than my 2008 DSM
Old 02-26-2013   #422
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Perfection.
Old 03-02-2013   #423
Looks great! I need to get going on mine.
Old 03-02-2013   #424
I think we all need to.
Old 03-02-2013   #425
blackrosenova400
blackrosenova400's Avatar
You know how the front case has the one larger bolt. You could put a small p-clamp there to add some more stability for the harness.
20g Mafia
Old 03-05-2013   #426
Mark Leasure
Mark Leasure's Avatar
Thanks for all the feedback, painting is so worth it on this stuff, the car is like new! Better than new.
The wire routing picture is deceiving, there are zip ties on the timing belt tensioner bosses and on the right side of the assembly there are two zip ties that have anchors. It is kept well out of the way of the timing belt. Kiggley did his home work on this one. I work in the transportation industrial market and this would never be up to my standards for acceptability, however it will never be put through that lifetime of abuse that I’m typically expecting.
Update:
I have the fire wall and brackets done now, fuel system is under control, AEM Twin fire box, and the Aeromotive regulator are all mounted up. I have also found a new tool that I love. A threaded insert installation tool, makes all this stuff look factory installed with real fasteners instead of zip screws. Good stuff! Menards carries the guns for around 15 bucks, they are garbage but if you shim them they work good.
The harness will end up being a sizable challenge. I now have all of the lights wired, still need to add switches to activate head/paring lights (one simple toggle switch) and a switch for turn signal indicators. I used XLPE jacketed wiring, found it in 20 foot lengths on ebay, for a good deal.
www.maperformance.com
Old 03-05-2013   #427
b00sted_spyder
Have you ever thought about tucking the brake lines? Man that is so fresh and clean!
Old 03-05-2013   #428
Mark Leasure
Thanks. I have not thought about it, need to draw the line somewhere! After all it’s a race car, not a show car even though it’s kind of looking like it these days. Just one radiator hose failure, frost plug blow out or major oil leak away from being normal again...
Old 03-05-2013   #429
4seasons69
4seasons69's Avatar
Looks awesome!
Old 03-06-2013   #430
Amazing.
Old 03-06-2013   #431
Hot damn, thing could be a show car! Looking good Mark!
Old 03-09-2013   #432
Knoxville
Drives: 09 G8 GT
Impressive, very impressive
2009 G8 GT
Knoxville is offline   Reply With Quote
Old 03-09-2013   #433
You have a pic of what exactly you're talking about here? I'm not quite understanding or picturing what this is, or what you're saying it replaces. But interested to know!
Old 03-09-2013   #434
I think he is talking about a PEM nut inserter. Basically installs a threaded insert in sheetmetal.
Old 03-09-2013   #435
enasnitsi
Drives: 1993 Talon Awd
Its this tool.
http://shopmenards.com/main/mobile/t...783-c-9135.htm
enasnitsi is offline   Reply With Quote
Old 03-16-2013   #436
Mark Leasure
I had a good week working on the car, I’ve been burning the candle at both ends of the day lately. I finished the wiring under the hood, this was no easy task. It took a little more effort that what I thought. I also made new fuel lines to connect up to my fuel rails.
I also built a bracket to route and control the new wideband wiring to keep it away from the hot piping.
Next step is to start the interior wiring and its ready for lots of tuning work to deal with the upgrade to the series 2 EMS.
Old 03-16-2013   #437
God your work is so clean I love it. Have you thought about tucking the throttle cable underneath the manifold?
Old 03-22-2013   #438
Mark Leasure
I finished up under the hood last weekend. This has been one awesome project, I did way more than what I expected! I'm getting excited to start the tuning process. I just need to finish up the fuel pump/controller and instrument wiring then get a modified deep sump pan oil pan on it. I start school April 1st so time is ticking.
Old 03-22-2013   #439
What are you going to school for? Just furthering your education?
Old 03-22-2013   #440
Mark Leasure
Yep, continuing my education, starting an MBA.
