Old 12-03-2012   #1201
Re: beaterX project thread
I would do a leakdown test. It won't tell everything, but might help you decide if you are going to pull the head. If the valve seats are compressed, then you might also have worn valve guides, which can cause more oil usage or even cause one of the valve guide seals to get knocked out of place.
Old 12-03-2012   #1202
Mark Leasure
Mark Leasure's Avatar
I agree with Shane on the leakdown test. At least it gives you something concrete to analyze, I know in our professional lives we have a common consensus that data is king and no smart/intelligent decision can be made without it!
I’m speculating the sparkplug failure event could have messed up a cylinder wall a little, that would be worse case??
www.maperformance.com
Old 12-16-2012   #1203
Well the weather outside is frightful, leakdown/compression numbers are trightful, let it go let it go let it go
Evo leakdown results:
1- 50% air from intake & exhaust
2- 50% air from intake & exhaust
3- 20% no leak at all*
4- 50% air from intake &exhaust
Cold compression
110 140 130*110
Walkin in an Evo wonderlaaaaaaaand.
Dear Santa....
Old 12-16-2012   #1204
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Those numbers sadden me
Old 12-16-2012   #1205
still seemed to make good power for that kind of results if you want to look at the positives
Old 12-16-2012   #1206
hell yea! Plus it's 'just' the head. Making plans now for when to get it yanked off, fixed, and re-installed.
Old 12-16-2012   #1207
It's a dsm, let r buck
Old 12-16-2012   #1208
mighty putty??
Old 12-16-2012   #1209
Heh! Problem is the car just sounds like shit. It sounds like a diesel until its fully warmed up and oil hot and even then it's not right.
mighty putty??
Yes but where to put it, the coolant or the oil?
Old 12-17-2012   #1210
TheBlizzard
TheBlizzard's Avatar
Drives: Too Many
Low compression = Moar boost = No more problem
Old 12-17-2012   #1211
Ouch...
Old 12-17-2012   #1212
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Sucky dude
Old 12-17-2012   #1213
2jz swap. Found you a whole engine for under 1k !
Old 12-17-2012   #1214
Time for a valve job.
Old 12-17-2012   #1215
Mark Leasure
Time for a valve job, maybe some better valves too? Are the factory X valves SS and do they have bronze guides?
Old 12-17-2012   #1216
Heh, I did that already, see fall dyno day thread
Hell yes!
Yea, thats the plan. Gonna get through the holidays and then rip the head off and try to get it fixed asap. The head already has supertech +1mm valves in it, not sure they'd be not good enough...
Old 12-17-2012   #1217
Murlo26
Murlo26's Avatar
Supertechs are nice ones. They have been solid for me, I have the same ones and those have been through two motors on my car. I don't think quality or durability is the problem, at least with the valves, maybe another weak point?
Old 12-17-2012   #1218
What springs do you have Murlo?
Old 12-17-2012   #1219
Murlo26
Murlo26's Avatar
Supertechs.
I was going to do Manley's with my build but for whatever reason the Manley ones for the 4b11 are not "manly" and couldn't support the lift on my cams.
edit: sorry for going OT.
Scheides what springs do you have again? Maybe that is your issue? I doubt it though.
Old 12-17-2012   #1220
I think his are the same as yours; that was my initial hypothesis.
