Old 05-25-2011   #1841
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Fueling system died on the way to work and I barely got it into the office parking lot. The 044 in the trunk is making horrible death sounds. I'm going to have to do some parking-lot troubleshooting later today but it appears toast.
Old 05-25-2011   #1842
Re: Evo X upgrades
Time to start using real brand name pumps rather than these modified/generic knock-offs?
Old 05-25-2011   #1843
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I had a Bosch-brand 044 first and it didn't flow enough--it'd immediately overheat if you tried to BAP it. There's a reason that the Weldon was waiting to go in.
Old 05-25-2011   #1844
Re: Evo X upgrades
Ugh that is horrible news dude. That was the jay racing 044 right? Do they by chance make a submersible version?
Old 05-25-2011   #1845
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
No, they have the PT342 which is what I'm running in the in-tank. It supposedly flows 340lph like the Aeromotive. I put my ear up to it and it's humming away in the tank. I'll verify flow from it before I swap my Bosch in tonight but it sounds happy.
Old 05-25-2011   #1846
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
As is often the case, the problem was not AT ALL what I thought it was. It turns out that the Jay Racing PT342 is actually a rebadged Aeromotive 340. What's interesting about the Aeromotive? Reverse polarity! It don't pump so good when wired backward. It does make sounds like it is working, however. lol.
I drove all the way to work on the 1/2gal that was in my surge tank.
Old 05-25-2011   #1847
Re: Evo X upgrades
Ah WTF!
Gonna be doing some wiring tonight then? lol
Old 05-25-2011   #1848
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
No real harm done since I didn't need a tow, so I'm laughing! lol.
I pulled the hanger and brought it home. I figure I'll go into work early tomorrow and drop the re-wired hanger back in the Evo. My boss was kind enough to give me a ride home to grab the beater.
Old 05-25-2011   #1849
Re: Evo X upgrades
Wouldn't most of the fuel from the surge tank just pass by the rail and go back into the primary tank via the return line? It seems like it would only take a minute for the external pump to go through the surge tank if the in tank pump wasn't doing anything to fill it.
Come to think of it, my 255 filled a gallon container in about a minute. Under throttle, most (if not all) of that is going to be used, but just cruising maybe 1/20th will be used, which means most of the gas just comes back through the return.
Is your surge tank 1/2 gallon? If so, it would only take about 30 seconds of your in-tank pump not flowing anything to run the surge tank dry, just because the external pump is always going to be flowing a lot, regardless if the motor uses it.
Or am I just high and not thinking clearly? Or maybe you have a return into the surge tank?
Old 05-25-2011   #1850
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Correct, the engine return goes to the surge tank. Overflow from the surge tank returns to the main tank.
Old 05-25-2011   #1851
Re: Evo X upgrades
Oh nice, didn't even think of that until after I wrote the post.
Old 05-25-2011   #1852
Re: Evo X upgrades
Ok that is my big beef with the aeromotive pump, why on earth would they wire it backwards from the product they are directly trying to compete against? Makes ZERO sense!
Glad you figured it out, that is just nuts!
Old 05-26-2011   #1853
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
The polarity fix got the pump working, of course. The problem is that it has too much flow for the return on the stock hanger and is pressuring the surge tank to ~6psi. This causes it to spring a leak at the 044 pump connection.
I think I've seen forum posts about ways to make the return less restrictive. Otherwise I'll need to downgrade that pump to a 255.
Old 05-26-2011   #1854
Re: Evo X upgrades
Would it be easier to swap in a larger return line? like -6 or -8 or something? What size is it now? Then you could have the extra flow you may need down the road, AND have it not overflow. Either way, glad to hear ya got it working!
Old 05-26-2011   #1855
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
The line isn't the restriction, it is within the stock hanger. They have a restrictor that creates the venturi effect used to pull fuel over from the other saddle in the tank. It was designed with stock flow in mind. Some people drill it out a bit but it's a little risky because if you drill it out too far then it stops drawing from the other saddle and you run out of gas with the gauge reading 1/4 tank.
Old 05-26-2011   #1856
Re: Evo X upgrades
Sell and replace with stock, 255, or DW300?
LMK if you need a stock pump.
Old 05-26-2011   #1857
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
We will see. I have a pair of 255 in the Full Blown hanger so I could pull one to test with.
Discussion about increasing the return capacity:
http://www.evoxforums.com/forums/showthread.php?t=28036
Old 05-26-2011   #1858
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
It looks like air in the fuel lines is my problem. I purged the surge tank/return and now that's all happy. I snugged up the surge tank fittings so no more leak.
Right now I'm getting no fuel pressure to the rail so I suppose there's air in that line as well. I ran out of lunch hour so I'll have to decide what to do with that later.
Old 05-26-2011   #1859
Re: Evo X upgrades
Air in the feed line shouldn't matter, if your pump is running it should push those air bubbles out.
Old 05-26-2011   #1860
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Spend quite a few hours experimenting. It certainly appears that the return line for the stock in-tank hanger is too restrictive. I just swapped a regular 255 into the hanger and will give it a try in the morning. The car seems to run fine if I leave the in-tank pump unplugged but everything I tried with it running would result in fuel pressure going to 0 at the motor. I even swapped in the Bosch instead of the Jays 044 and the symptoms were identical.
I hope the 255 works. If not then I'll probably try cutting off the return hose in the hanger to bypass the restrictive return/siphon. Too many people eyeballing my car...leaving it parked in one spot for too long is making me nervous. I need to move that car tomorrow...even if that means running off the surge tank and stopping half-way home to refill it.
