Old 02-17-2010   #21
Re: Polishing the cast manifold.
I say skip polishing the manifold and buy a sweet body kit.
Old 02-17-2010   #22
+ wood screws
Old 02-17-2010   #23
Maybe ceramic clear coat? Is there such a thing?
haha
+ wood screws
I hear gorilla glue holds good too lol
Old 02-17-2010   #24
R is for race.
Old 02-17-2010   #25
Long story, you didn't know his old 2g...
Old 02-17-2010   #26
The thing with ceramic coating is that it needs something to grab on to (mechanical adhesion) and if you polish the manifold, there won't be anything for it to grab on to and the first time it gets hot it's all gonna fall off.
Old 02-17-2010   #27
Exhaust manifold not intake manifold. Thought i would correct you so that some kid doesnt try to put an intake mani on the exhaust side.
How about your sheet metal exhaust manifold idea? That would be nice and shiny. SMEM anyone?
Old 02-17-2010   #28
Best way is to throw it in the trash and get an FP exhaust manifold.
And then watch it rust, or at least look like absolute dogshit. I'm coating mine this spring.
Old 02-18-2010   #29
blackangel42
blackangel42's Avatar
Drives: 06 evo mr 93 stang 5.0
well i've done some cast metal polishing. u can clean it. to get it smooth your going to have to sand it down alot. starting with very coarse slowly higher and higher grits up to highest grit u can find. 3m has a wet 3000 disk. sometimes water help the high grit papers from clogging up so fast. then some sort of buffer or polisher with high speed 3000rpm least. but dont go to high. and use some heavy compond or metal polish up to a fine polish so get that shine. car parts store in body section or body supply store will have it. then i would look into clear powder coat. or sand it smooth and have it cromed or nickel coated would work too. it would probably be easier to have it coated with something after u sand it smooth. it will be hard to polish in all the little spots.
blackangel42 is offline   Reply With Quote
Old 02-18-2010   #30
Ok, lets see some pics of this thing already!!
Old 02-18-2010   #31
Ill post some tomorrow. its far from finished. but im at a standstill with the project right now because the piston and rod havent come in, so i will have time to get the manifold nice, and make you all jealous. WOOT. then i figure after its done and if it starts to rust a bit, just grab some steel wool and wha la, back to shiney.
Old 02-18-2010   #32
As strange as this sounds, I actually watched a guy do this at a car show. He had the engine up to temp and idling, then started spraying Armor-all on his exhaust manifolds. The Armor-all turned a charcoal grey and solid. Looked just like a ceramic coating. Craziest thing I ever saw. When the engine cooled off, it was hard to the touch and stuck like crazy glue. No bull shit, I swear, I'm not making this up.
Old 02-18-2010   #33
I'd be all for the Armor All idea, but I also want the heat retention a good coating can provide. The FP manifold makes the front engine area noticeably hotter than my previous manifolds. Heat dispersion before the turbo=bad.
Old 02-18-2010   #34
Pics so far. Im getting kinda sick of doing this already. LOL
ID:	9752   Click image for larger version
Old 02-18-2010   #35
How much time into it so far?
Old 02-18-2010   #36
Days man, DAYS,...............
Old 02-18-2010   #37
Like between today and tomorrow..... about an hour and a half. maybe less than that.
Old 02-18-2010   #38
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
looks good, at least your not doing it by hand...lol
Old 02-19-2010   #39
Still looks like a turd. FP mani for the win, Steve is right it did make the bay a lot hotter, but once I got mine coated it was a lot cooler.
Old 02-19-2010   #40
Have fun keeping it from rusting.
