Old 02-03-2009   #1
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
How to clean a headliner?
So I bought my car and the headliner had water stains on it and I took it out. The headliner is in really good shape besides the stains so I was thinking... Can I have it dry cleaned?!?
What is your opinion? Also what do you guys think I should do about cleaning it if the dry cleaning isn't a good idea?
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 02-03-2009   #2
Re: How to clean a headliner?
How about some spot stain remover made for upholstery? Should work well and not damage the fabric.
Old 02-03-2009   #3
GsXtUrBo98
GsXtUrBo98's Avatar
What would I use to scrub it?? or would I just let it soak??? I tried to clean my gf's 2g talon's headliner and it started wrecking the fabric..
98 GSX (built)
03 BBY EVO dd
Old 02-03-2009   #4
go gently at with with a white cotton rag and/or a soft bristled brush.
Old 02-03-2009   #5
GsXtUrBo98
GsXtUrBo98's Avatar
The bristle brush is what i uesed and it messed it up.... : (
worth a shot though... thanks for the help
98 GSX (built)
03 BBY EVO dd
Old 02-03-2009   #6
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
just blot at it with a rag versus scrub and you shouldnt mess it up. Wont get nearly all the stains out, but oh well
Old 02-03-2009   #7
GsXtUrBo98
GsXtUrBo98's Avatar
So you guys don't think that I should get it dry cleaned or steam cleaned? I'm not sure if those are both the same but ya...
98 GSX (built)
03 BBY EVO dd
Old 02-04-2009   #8
Scrmegl
Brian
Scrmegl's Avatar
Danger Wheels Champion!
Drives: '98 TSI AWD
Send a message via MSN to Scrmegl
Steam could likely loosen the spray adhesive and cause stretch/sags. If done very careful over a cloth to transfer it might work. Just don't work or scrub. Spray/blot works ok. I've used an extractor before with only partial vac and slight rinse after a spot treatment (first wet wider than spot spray area to avoid clean ring lines and work outside in on stains).
A Body to G Body to F body to 2G DSM
Scrmegl is offline   Reply With Quote
Old 02-05-2009   #9
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
The blue coral carpet/upholstery spray cleaner works very well and you just spray, wait a few mins, and dab to lift the stains. It took out stains in my 2g carpet from the previous owner, so the stains had to have been at least 4 years old. Last time I checked, it was a blue and white can at wal-mart in the auto area by the polishes.
