Old 01-23-2008   #61
Re: My Winter Upgrades
As far as the exhaust side goes, it's the smaller of the 2 exhaust wheel options. Here are all the specs I believe it is. I just wrote them asking for verification of it all.
Compressor Wheel: inducer-62mm / exducer-84.6mm / 54 trim
Exhaust Wheel: inducer-76.1mm / exducer-66.7mm / 77 trim
Exhaust Housing: .70 A/R, T3 inlet, V-Band outlet
Compressor map attached below. Also I'll post up a map of a .70 A/R GT35R for comparisons sake.
Name:	S362 Comp map.JPG
Old 01-23-2008   #62
Also I was going to mention that it is oil cooled as well which I really like because of simplicity in the engine bay. Less lines going places =
Old 01-23-2008   #63
mdost03
Sonic Champion!
Drives: VA STI
That's a very sweet turbo man
Old 01-23-2008   #64
How are you going to plug the water lines from the origional setup then?
Also, are you ceramic coating both the manifold and exhaust housing?
Old 01-23-2008   #65
That's a pretty big exhaust wheel, should make some power.
Old 01-23-2008   #66
The last setup was oil cooled also.
And yes, I'm having that Form and Function place in St. Paul coat my manifold and exhaust housing.
Old 01-23-2008   #67
Also, just picked up the aluminum from Discount Steel to start building my intake manifold.
Old 01-23-2008   #68
Sweet! Keep us posted on your progress on the Manifold.
Old 01-25-2008   #69
I will keep you posted on the manifold progress.
I did just pick up my new Fidanza 4.3 clutch from MAP, thanks guys!
Old 02-07-2008   #70
Just received and installed the new CF hood today. I'd have pics but my digi cam is busted, and Derek's ran out of battery.
Also I started on the intake manifold. I have the runners cut, and have begun working on the plenum/runner flange.
Old 02-08-2008   #71
FFPerformance
Looking good B. I know we talked a little about your build but after reading this, you were holding out on me
FFPerformance is offline   Reply With Quote
Old 02-08-2008   #72
Thanks man. Nah I wasn't holding out, just not trying to toot my horn to you.
Here's the pics of the stuff I got coated from FFP.
http://server6.theimagehosting.com/a...hp?album=31608
Happy with how it turned out. Can't put it on yet though because I realised I had no fittings for the oil lines. I want to wait for those fittings before putting this all on.
Also since I'm going to Spain here in a week or so, the car probably won't be up and running until this Spring.
Old 02-11-2008   #73
Update with some pics.
ID:	6952   Click image for larger version
ID:	6953   Click image for larger version
Old 02-11-2008   #74
Looking good man.
Old 02-11-2008   #75
The new hood somewhat on.
ID:	6956   Click image for larger version
Old 02-11-2008   #76
b00stcreep21
I hate everyone
b00stcreep21's Avatar
Oh snap, JDM fiber. Lookin good dude
Old 02-11-2008   #77
looks good
you need to get the carbon pop ups also
Old 02-11-2008   #78
That and I need some different rad fans since I had to remove one because the turbo gets in the way.
Old 02-11-2008   #79
Shouldn't need too much for fans with that radiator and E85.
Old 02-11-2008   #80
That's what I hear. Except I experienced a much different thing from that, while trying to keep my car from overheating all last year.
http://www.dsmstyle.com/forums/showt...ht=running+hot
