Old 09-14-2006   #21
Re: am i the only one with this problem...
6bolt block
2g pistons
Stage 2 2g head
PTE 50 Trim
Ported Exhaust mani
Tial Wastegate
Greddy Type S bov
680cc injectors
DSMLink
3s Fuel Pump
Custom FMIC with 2.5" piping
ACT 2100 clutch
Fidenza Flywheel
3" Custom turboback exhaust
Forge UNOS boost controller
Tokico Struts
Magnacore Race Wires
I think im missing something but ill add later if i am.
Old 09-14-2006   #22
Shotgun!
Totenritt
Shotgun!'s Avatar
That's a nice list!
Old 09-14-2006   #23
too bad the car doesnt start, the gremlin got into the wires under the steering wheel and made a nest, and managed to mess something up under there, guess he was hungry. I managed to find a relay that was broken, but i think its the clutch switch thats messed up.
When i try and start the car nothing happens but if the car is in the on position it the radio will come on and everything is good. then i try and start, and nothing.
Old 09-14-2006   #24
Damn What are you driving in the meantime?
Old 09-14-2006   #25
Enes
Enes's Avatar
Originally Posted by ecoli
Remove balance shafts, install lumpy cams, install stiffer motor mounts, watch car unbolt itself.
I got all those and 14000 miles later still together, however i do have a front case gasket leaking gremlin..
Old 09-14-2006   #26
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
locite is your freind i had a few issues w/ that happening
Old 09-14-2006   #27
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Think about this. Go try and start a different manual transmission car without pushing in the clutch (assuming they still use their neutral safety switch) and see what happens. It will do the exact shit you're talking about. Have you thought about disconnecting the neutral safety switch? It sounds like your car thinks your clutch is never pushed in ^^ It's a simple conecept. Unplug and be happy At least that's how it works on a 1g.. I'm not familiar with 2g's.
- Josh L.P.
Old 09-15-2006   #28
Thats my exact thoughts, Heres the problem though, Its already bypassed, so before this whole thing happened i was able to start it without pushing in the clutch.
Can anyone verify if all i need to do is disconnect the switch? or does anyone have this done and know what all i need to check?
