Old 08-06-2005   #1
Enes
Enes's Avatar
melting headlight plugs
OK, i'm sick and tired of these stupid headlight plugs, i changed 2 already and they keep melting.
Its probably lightbulbs that i'm using but the plastic on them isn't melting only the plug on the wiring harness side.
has anyone else had an issue with that or know a different way of doing it?
Old 08-06-2005   #2
Onefast99gsx
Re: melting headlight plugs
What you using for bulbs are how much power are they pulling? Perhaps the wire isn't a high enough gauge.
Old 08-07-2005   #3
Emcee gsxtc
Emcee gsxtc's Avatar
This is a common problem with cheap ebay bulbs. If you pay the money for Silverstars or other quality brand headlights you won't have a problem. I know of 3 cars that it has happened to, and all had bought cheap ebay "high intensity" or "blue look" bulbs.
Sylvania silverstars are sold at Wal-Mart, Autozone, and other auto places. At least the more common bulbs. Finding them for my Audi was a pain, and they are a little pricey.
Run your car not your mouth!
Pick Two: FAST CHEAP RELIABLE
Old 08-07-2005   #4
Silverstars are amazing bulbs as far as non-HID headlights are concerned, well worth the price IMO (and I paid $25/bulb, they are under $20 now). They look very nice plus give more light than any bulb available here in the US (a European Phillips bulb and the European version of Siverstars provide slightly more light than the US-spec Silverstar b/c the US-spec has a very light coating to give them an HID-like appearance).
Old 08-07-2005   #5
Alpine TSi
Banana Hammock!
Alpine TSi's Avatar
Drives: Shitbox
+1 to Silverstars, I will be using them in the Galant once I get my foglight situation figured out.
1992 Eagle Talon TSi AWD
320awhp/320lb-ft tq
12.772 @ 108.57
1992 Mitsubishi Galant VR-4
678/1000
Old 08-07-2005   #6
Enes
Enes's Avatar
Actually that is what i have, Silverstars
i guess i'lljust go back to the crappy ones...
-E
Old 08-07-2005   #7
Have you checked the voltage in your car Enes? Make sure the voltage isn't higher than normal, your voltage regulator could be going out on the alternator.
Old 08-07-2005   #8
Enes
Enes's Avatar
i do ocasionally see 14.2 14.5 .. mostly around 13.7 13.8
Old 08-08-2005   #9
CarPsyco84
CarPsyco84's Avatar
bad connection to the bulb? crud or somthin on either the plug or bulb, if the plug is loose on the bulb, it could also cause arcing, this happened on my bike once... course if it was arcing you would notice the dimmness of the bulb... but it wouldn't have to arc long to melt a plug
-When in doubt, Moar RPM.
