Old 11-05-2013   #1
Winter mods 2013/2014
What does everyone have planned for winter mods this year?
Here is my list:
15/16" CE28N wheels with Toyo Proxes RA1's
Replace unknown fuel filter (with hose ends) with FuelLab filter and -6 lines to match the rest of the fuel system
Fix order of pump and filter so the pump pushes through the filter instead of pulling
Install fuel level gauge
Install clam mounted APR wing in place of stock wing on hatch
Corner balance
Maybe:
OMP Superquadro wheel
Real CF roof if I can sell the stock roof and full mohawk roof
Old 11-05-2013   #2
93gtpeater
Drives: cbr 1000rr repsol
Re: Winter mods 2013/2014
I plan on saving money to have a driveshaft built for the truck and buy a new dipstick assembly for the transmission.
For the bike I need the fork seals replaced, front brake recall performed, oil change, and buy a brocks clutch mod. Maybe man up and get a turbo kit for the bike in the spring time
Old 11-05-2013   #3
Put motor in the drag r1 so I can drag race next year.
Would like to get an easy pull clutch lever for the new stunt bike. Then general clean up of the wiring and maybe paint it.
Get a trailer hitch for the gto.
Get my fatass back in shape so I can man handle the stunt bike a little better and go faster on the drag bike lol
What color volks you getting Andrew?
Old 11-05-2013   #4
I didn't know you had two bikes now, what is the stunt bike?
Getting them in flat black. Thought it would hide brake dust the best haha.
Old 11-05-2013   #5
4seasons69
4seasons69's Avatar
Part the devil car out! Muhahaha
Old 11-05-2013   #6
Yea, had two r1's for a while then traded for the stunt bike plus some cash to save some money up over the winter. Stunt bike is just a normal bike but with a big crash cage, wheelie bar and other mods to make it easier to do tricks with.
https://scontent-a-ord.xx.fbcdn.net/...66839895_n.jpg
Pretty funny video of me 2nd time out trying to learn slow wheelies:
http://www.youtube.com/watch?v=9I-domXF9oo
Flat black should look sweet, especially if you get that carbon fiber roof! Your car is so nice
Old 11-05-2013   #7
HAHAHA nice vid.
Old 11-05-2013   #8
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
I don't know what I'll do. Either I'll pick up a shell and start the boosted V8 Datsun project, or, scrap the idea of building another fast car and put money into the Raptor for suspension and performance mods.
Old 11-05-2013   #9
cmspaz
Walls need hugs too
cmspaz's Avatar
My winter mod is going to be a replacement Evo, and prepping it.
Originally Posted by Trogdor
Old 11-05-2013   #10
Get the car solid for passes in 2014.
Go thru the auto trans.
New exhaust that fits good.
Install Kirkey drivers seat.
New converter possibly.
Intake pipe
GM MAF or SD.
Mods to go faster.
Old 11-06-2013   #11
blackrosenova400
blackrosenova400's Avatar
Converter
Better trans cooler location/setup
Transmisison Temp Gauge
Coil on plug
Rebuild driveline
Replace all suspension bushings with energy bushings
Maybe rear active toe elimination kit
20g Mafia
Old 11-06-2013   #12
hahaha nice video brad!
My plans?
Get motor in the beater.
Go through trans with some help to make sure its good to go.
Get the fucker running hopefully?
Try to sell the 16g for the sweet deal on a bolt on 5857 maybe? If not then just run 16g, no biggie
Old 11-06-2013   #13
Buy new tires come spring. That about sums it up
Oh, I need to replace a corner marker light that burned out and eventually take my car in for the CMC recall.
Old 11-06-2013   #14
On the owdee -Timing belt, water pump, thermostat and housing, rear coolant valve replacement, VC gasket, and a bunch of other maintenance, figure out why my power steering started to make a grinding noise at full lock in the next few weeks.
Decide if I want to keep it come spring and replace it with something else. Or get a second summer car.
Old 11-06-2013   #15
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
sell my 30r off the STi and replace it with a 35r and get some 1600cc injectors, come tax return if i have the money spec.B long gears should get me into the mid 10's
Originally Posted by 311evo
Old 11-06-2013   #16
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Well, this winter is going to be a lot of changes for myself:
- New all aluminum exhaust (probably from STM, maybe have MAP build me a custom one) and testpipe.
- MAP rev 3 intake manifold (have already)
- MAP 64mm ported TB (have already)
- Zeitronix E85 ethanol content sensor and display (have already)
- AEM boost, fuel pressure gauges (have already)
- ID 1300cc injectors
- Radium wally 400 surge tank and new wally 255 in fuel tank with necessary lines/mounting
- Full Race IC and charge pipes
- Full Race 7670 EFR T4 TS turbo kit
- girodisc 2pc rotors (have rears already)
- New tunes!
Going to be a long winter, plenty of time to install all this. Most of it will come after tax return time
Old 11-06-2013   #17
Do you have pics of MAP's TB?
Old 11-06-2013   #18
Murlo26
Murlo26's Avatar
Not yet, it shipped yesterday, I will post some up when I get it for sure. Took a while as it was their first batch and they had to order replacement seals and what not to make sure it was good to go.
Old 11-06-2013   #19
93gtpeater
Can we ban Murlo from this thread since we all know he will change set ups mid winter....
Old 11-06-2013   #20
Murlo26
Murlo26's Avatar
LOL, isn't this a "plan" thread
