Old 05-13-2008   #1
dustinw
dustinw's Avatar
Drives: 96 Talon TSi AWD
question for the 3s guys
looking into getting a stealth TT this weekend.
the guy is claiming 450 awhp.
i know theres a shit ton of variables but with these mods, do you guys believe 450 awhp is possible with this setup? im thinking more like 375-400 but thats just me.
1992 Dodge Stealth R/T Twin turbo AWD, Dynamic Racing stage II heads, 99 lifters, 6-speed Getrag from 99 vr4, Southbend Stage 4 DXD-B Clutch, TEC 15g's, Greddy blow off valve, Dejon Powerhouse Blow-Thru Intake Pipes, DSM sidemounts, Denso fuel pump, 550cc fuel injectors, Apexi SAFC, HKS VPC, Apexi AVCR, msd ignition dis-4, MSD 8.5mm wires, NGK coppers 1 stage colder, y-pipe, borla catback, ATR downpipe, highflow cat, Lowered, Nitto tires.
dustinw is offline   Reply With Quote
Old 05-13-2008   #2
dustinw
dustinw's Avatar
Re: question for the 3s guys
car will also be coming from 7300ish elevation down to 2200 or so
Old 05-13-2008   #3
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
the elevation change will have an effect. coming down should make it run better due to more oxygen i believe.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 05-13-2008   #4
Is that pump or race gas? what is he using for engine management?
Its doable on pump i wouldn't doubt it too much.
Old 05-13-2008   #5
DSM_421
Those injectors seem kind of small.
I guess you will have to test drive it, should give you a good idea on how much power it is making.
Old 05-13-2008   #6
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
We have 6 injectors. That's like 825's in a DSM.
Has a HKS VPC too. Old school, but works good.
As for making 450, it's debatable but not out of the question. The DR heads are a big help. Also if it was dyno'd at altitude with corrections, it will bump the #'s a little.
Old 05-13-2008   #7
DSM_421
Yea I guess that makes sense, but you also have 6 cylinders. But I guess with two extra cylinders you don't need big injectors to make that kind of power.
Old 05-13-2008   #8
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I would believe at least 350 which is good however you look at it.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 05-13-2008   #9
dustinw
dustinw's Avatar
not sure on engine management, and its on pump gas.
Old 05-13-2008   #10
vr-4lif3
"550cc fuel injectors, Apexi SAFC" I doubt it's at 450 with no timing control.
vr-4lif3 is offline   Reply With Quote
Old 05-13-2008   #11
dustinw
dustinw's Avatar
heres what im trading him for it :
http://s32.photobucket.com/albums/d1...t=P1050657.flv
Old 05-13-2008   #12
DSM_421
The engine management would be the SAFC.
Old 05-13-2008   #13
I say keep the camaro.
Old 05-13-2008   #14
dustinw
dustinw's Avatar
the camaro gets about 8mpg, and its only a 3 speed. i need a car that can be a daily driver too.
Old 05-13-2008   #15
dustinw
dustinw's Avatar
the camaro has a built 383 stroker with eagle rods, pistons, crank. all forged
.510 lift cam
9.8:1 compression ratio.
Dart iron heads
Holley HP series 750 Double pumper carb
MSD ignition, wires, and distributor.
K&n Filter
built th350 tranny. Overdrive has been removed.
3500 stall converter
Aluminum flywheel
B&M Megashifter ratchet style.
10 Bolt Rear end, brand new 4:10 gears
3:73 gears included.
Posi LSD
30 Spline Axles
Electric Fuel Pump
Edelbrock headers
3" exhaust, hollowed out cat. (very mean sounding)
Push Button start
200 Shot of nitrous
Aluminum Radiator with electric fans.
spohn racing torque loop
spohn racing subframe connectors
spohn racing adjustable torque arm
Old 05-13-2008   #16
NOT THE BLUE LAMPSHADE
ROFLCOPTER!!!
I know for that every 1000 feet in elevation you climb, you lose 3% of your engines output capacity, and vice versa for descending in elevation, so you gain 3% every 1000 feet. So you should get a good bump in power going down 5000 feet; roughly 12-15% or so gain. But I don't know how they compensate for a tune. I'm almost positive you will have to get it re-tuned when you bring it back to your elevation. Atmospheric pressure @ 7000 feet is 11 PSI and @ 2000 feet it's around 13.5 PSI or so, and that's a good difference.
Just out of curiosity, are you buying the car somewhere in Wyoming?
Any of the tuners here know what the deal is with getting a re-tune?
Old 05-13-2008   #17
DSM_421
He will have to get it retuned for sure...
Old 05-13-2008   #18
ROFLCOPTER!!!
thats what i figured because my friend has a 400WHP evo in littleton, co (~4000 ft) and hed have to get a retune if he were to bring it up to laramie (7400 ft)
Old 05-13-2008   #19
dustinw
dustinw's Avatar
ok so if the car is running rich in laramie will it lean out a little bit more if he brings it down here?
Old 05-13-2008   #20
dustinw
dustinw's Avatar
what im saying is i think he got it in wisconsin and it was tuned. then took it to laramie without retuning therefore running rich the whole time. so maybe returning to a normal elevation will bring it back closer to that optimal range.
