Old 03-23-2016   #1
import_boi
Drives: ae86,2ga,
Part out :(
Dsm part out 97% of the parts are barley used(less than 1 month)
Fuel system
$80 Walbro 255
$250 -6an fuel line from pump to fuel filter (costed me 300 to make)
$10 wix fuel filter
$100 used evo 560 injector
$160 fullblown fpr (w/gauge,and -6an fittings
$40 fuel rail with AN fitting adaptor
$40 -6an line from rail to regulator
Turbo system
$300 Ported and polished fp race exhaust manifold (surface rust but I can steel shot it at work)
$200 evo 3 ported turbo with j pipe
$100 -10an drain line
$20 oil feed line
$100 turbo intake, with 2g maf
$200 cx racing fmic short route kit with crushed 1g bov and bung welded on ic pipe for speed density
$695 2g ecm link v3 full, gm speed density kit with plug n play harness
$1500 6bolt long block drop in
Brand new cylinder head!!!!!
L19 head studs
Cosmetic mls head-gasket
Gates racing timing kit (water pump, tensioner, and blue timing belt)
Balance shaft delete
All new gates belts
New reman alternator
120k miles on the bottom end
Compression test 150 across each cylinder
$500 transmission with no grinds or pop out
$200 t-case
$200 act 2600 and flywheel
$200 17 inch wheels
$200 fullblown dual core half size radiator with hoses
Prices are best offer too, the worst I can say is no
For faster response 6517886294
import_boi is offline   Reply With Quote
Old 04-26-2016   #2
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: Part out :(
Still have the Evo 3 turbo?
DSM....Because broken timing belts, cheap interior, transfer case leakage, and crankwalk is to weed out the weak.
Perkul8r is offline   Reply With Quote
Old 05-05-2016   #3
GSTPerformance
GSTPerformance's Avatar
Drives: 97 GST
Re: Part out :(
Hey, do you still have the ACT clutch?
Left foot on the clutch, right foot on the gas, right hand on the gears, left hand on the wheel, cruisin.
GSTPerformance is offline   Reply With Quote
Old 08-05-2016   #4
89_Colt_GT
89_Colt_GT's Avatar
Drives: Swifty Crazy
Re: Part out :(
Pictures of the wheels?
1989 Colt GT
2013 Ford Focus
1999 Buell M2
89_Colt_GT is offline   Reply With Quote
