Old 02-10-2011   #1
four-thirteen
Drives: 94 mitsu 4g15
4G15 head bolt torque and valve lash
Free mojito for the first person to correctly tell me the head bolt torque and valve lash settings for the 4g15 I am screwing together.
four-thirteen is offline   Reply With Quote
Old 02-11-2011   #2
Re: 4G15 head bolt torque and valve lash
What car is it normally in?
Old 02-11-2011   #3
Sorry, that answer only gets you a Shirley Temple.
Old 02-11-2011   #4
four-thirteen
It is a motor found in colts, eagle summits and mirages, and a bunch more. This one is from a 94 eagle summit.
Old 02-11-2011   #5
Using sequence shown in Fig. 4, tighten cylinder head bolts in two or three steps to a final torque of 53 ft. lbs . Cylinder head bolts must be tightened in two or three steps to ensure correct cylinder head to cylinder block seating.
VALVE CLEARANCE SPECIFICATIONS
Intake, Inch
Hot 0.008
Cold 0.004
Exhaust, Inch
Hot 0.010
Cold 0.007
Old 02-14-2011   #6
four-thirteen
Thanks Shane. The car runs and hasn't pushed out the head gasket or banged any valves so I guess you get the mojito.
