Old 08-02-2009   #1
cman3000
Colin
cman3000's Avatar
100m Running Champion!
Drives: 90 Talon TSi AWD, 73 Datsun 240z w/Built L28
Full Built 1ga Part Out!
Alright, il try this one more time. The way it will have to work is you let me know what you want, paypal me the cash and i will pick it up when i go home home and bring it to the cities. For the bigger stuff or things i will need help taking out (transmission, engine, etc.) we can meet in Brainerd over a weekend that works for both parties and pull the part(s). Pm me for more info.
Front axles - 50
Three Speed Shatter Shield 100
Rebuilt Driveshaft 50
New Carriage Bearings
New Front Hub Bearings & Seals
BRAKES:
Front Baer Brakes with Slotted Rotors - $550
New rear calipers with Slotted Rotors 75
Front Stainless Steel Braided Brake Lines 30
FUEL SYSTEM:
Supra TT Fuel Pump 80
Re-wire fuel pump relay
3" GM MAF
Braided fuel lines(3) - 65
INTAKE SYSTEM:
Bullseye T04B 50 Trim turbo (oil & water cooled, -10an oil drain) - $500
COOLING SYSTEM:
Alumium Mishimoto Radiator W/Slim Fans (One Puller & One Pusher) - $250
6an turbo coolant feed and return line - 70
SUSPENSION:
Suspension Techniques rear sway bar with Urethane Bushings - 40
New Front & Rear Stabilizer Bar endlinks - 35
RO_JA 18" Formula 5 lightweight wheels with 225/40/18 tires. - $700
AUDIO:
Pioneer head unit with detachable face and CD player with remote control,Polk Audio front and side speakers - 220 for it all
GAUGES:
Autometer Phantom:
30psi Boost/Vacuum Gauge 25
Oil Pressure Gauge 25
Volt Gauge 25
Water Temp Gauge 25
EGT Gauge w/sensor 50
125 for all of them
ELECTRONICS:
New small Battery 25
New Alternator 50
New Coil Packs 25
New Ignition Module 25
New Spark Plug Wires and Plugs(BPR7ES) 25
EPROM ECU with Keydiver Chip reprogrammed for the following; 8000 Rev Limiter NO Airflow CAP No Fuelcut Octane Reset Shift CE Light @ 7000 RPM Enhanced closed loop MAPS Knocksum Gauge 1200cc injectors/264us deadtime 3” GM MAFT 850 RPM Idle 45 PSI AFPR 11.0:1 WOT A/F FED/AWD Locked Baro & Airtem 180
INTERIOR:
Corbeau TRS Seats w/1g brackets - $500
cman3000 is offline   Reply With Quote
Old 08-02-2009   #2
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
Re: Full Built 1ga Part Out!
how much u want for block n head assembled
96GST16g is offline   Reply With Quote
Old 08-02-2009   #3
viridionplague
how much you lookin to get for the ksports and sway bar?
Old 08-03-2009   #4
cman3000
Colin
cman3000's Avatar
Only two people want any of this stuff?
Old 08-03-2009   #5
I would be on that tranny like stink on shit if it wasn't for a 1990...
Old 08-03-2009   #6
iceminion
iceminion's Avatar
Um, thats a 91+ transmission there buddy
building a 3000GT AWD Turbo.
Old 08-03-2009   #7
where does it say that?
Old 08-03-2009   #8
iceminion
iceminion's Avatar
I installed it. Its a 91+ you have my word.
Old 08-03-2009   #9
PM'ed
Old 08-04-2009   #10
santa
Boost Spike
santa's Avatar
Put up some pictures of those seats! or email them to me! kj182@msn.com
Old 08-04-2009   #11
cman3000
Colin
cman3000's Avatar
http://www.mitsustyle.com/forums/showthread.php?t=21536
Look at the bottom of the page.
Old 08-04-2009   #12
streetTERROR
streetTERROR's Avatar
Is the dnp header one for an internally wastegated turbo? Can I use it with my Evo3 and on my 7bolt head?
Nick Phelps
1993 Talon TSI AWD
streetTERROR is offline   Reply With Quote
Old 08-06-2009   #13
Tachyon
Tachyon's Avatar
Drives: Icarus
Are you located in Brainard, or can pickup be arranged in the TC metro area?
-Sebastian Vettel
Old 08-08-2009   #14
daneatsv8s
Drives: 91 Galant VR4, 97 Eclipse GSX, 91 Talon TSI
Could you do 250.00 picked up for the Megan exhaust? I could come to you. Thanks.
Dan
daneatsv8s is offline   Reply With Quote
Old 08-09-2009   #15
eagle talon guy
eagle talon guy's Avatar
Send a message via AIM to eagle talon guy
Willing to sell just the slim fans?
If you are, PM me a price
-Michael
(^^very old pic!)
6 Bolt build in progress
eagle talon guy is offline   Reply With Quote
Old 08-09-2009   #16
Swifty1638
Swifty1638's Avatar
I wonder if those brakes would work with my 16x8" Kosei K1's...also, wanna seperate that tree-speed scattershield?
Old 08-10-2009   #17
1slowdsm
Now 1 second.....slower!
1slowdsm's Avatar
Drives: 1993 Talon AWD
Do you still have the stock radiator harness? The plug wire that connects to the radiator fan from the fuse within the engine bay.
Old 08-10-2009   #18
viridionplague
how is the smim setup, more for street use or track use, what about the throttle body? and coil relocation bracket
Old 08-10-2009   #19
cman3000
Colin
cman3000's Avatar
I am located in Brainerd, but i could bring parts to people at the cookout, just need to be paypal'd ahead of time. That would work the best for me, and im sure most of you will be there anyways.
Old 08-10-2009   #20
CarRacer
CarRacer's Avatar
$20 for the volt gauge? Picture?
CarRacer is offline   Reply With Quote
