Old 04-23-2016   #41
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: 2011 Sti Build ?
I like purple obviously. It looks really good with white also i think.
Tyler
2011 Subaru Sti 11.0 @135mph
Old 05-29-2016   #42
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Well heres how far the car has came engine is 99% complete just need engine mounts then i can drop it in the car. Real close to being done
Tyler
Old 06-21-2016   #43
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Little update. Planning on having the car uo and running next spring ready for next season. Ill be sending in the shortblock i have now to be sleeved and then back assembled. Didnt feel like pushing what i want to at that blcok as it is now
Tyler
Old 12-30-2016   #44
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Havnt updated the thread in awhile so here whats been going on the shortblock i built first got tore apart to send the case halves out to get closed. The new case halves just arrived today stg4 iag closed deck, pinned mains, oringed deck, 14mm headstuds etc.. Also have been gathering some other parts as in all my fuel stuff and some other little goodies. Shortblock is getting assembled next week and then possibly after i get the longblock together itll go in the car possibly. We will see.
Tyler
Old 01-03-2017   #45
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: 2011 Sti Build
Time to get the shortblock assembled. Heres a list of whats in the new shortblock and whats done to it.
- Stg 4 Iag closed deck conversion
- Pinned mains
- O-ringed deck
- Manley turbo tuff i-beam rods with arp 625 rod bolts
- Manley turbo tuff extreme duty 99.75 pistons
- King rod / main bearings
- New oem 08+ Sti crank
Tyler
Old 02-09-2017   #46
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Longblock is assembled completely and hopefully going in the car this weekend if not next weekend. Heres a pic of the shortblock assembled and showing the orings.
Tyler
Old 02-09-2017   #47
Speedfreak
Drives: four tires
Using copper head gasket?
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 02-09-2017   #48
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Je Pro Seal headgaskets
Tyler
Old 02-09-2017   #49
Speedfreak
Drives: four tires
I don't believe that will work. That's a MLS.
An o-ring needs a maleable surface to press into. Which is a copper gasket.
You may ruin the o-ring if you use an MLS and torque it down onto that o-ring.
GSX - 571whp/490wtq
Sienna
Old 02-09-2017   #50
dsmDolney
dsmDolney's Avatar
Drives: Racecars
You are correct it is a mls gasket yes. It accually does not ruin the o rings itself
Alot of people run mls head gaskets with o rings and is accually recommended by some of the best subaru shops in the US
Tyler
Old 02-09-2017   #51
dsmDolney
dsmDolney's Avatar
Drives: Racecars
And any wire will cocentrate the clamp load making a better seal. Many people use a copper oring with an mls gasket so something deforms. The phusions are near because they have a gas filled wire already in them. The gas in the wire makes them compressible. If the head lifts the oring will be able to grow a bit and maintain seal.
Tyler
Old 02-09-2017   #52
Speedfreak
Drives: four tires
Just trying to help. Hope it works out for you. Not something I would do or suggest.
GSX - 571whp/490wtq
Sienna
Old 02-09-2017   #53
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Its been proven to work plenty of times im not to worried thanks for the suggestions !!
Tyler
Old 04-01-2017   #54
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Update on the Subaru, well the engine and everything is in. Waiting on a couple more small parts to come this week then it will be time to start. More updates to come after breakin.
Tyler
Old 04-21-2017   #55
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Started the car for the first time in 2 years and it was definitely a relief. Its 100% done and ready to rock we get it on the rollers this coming Thursday.
Tyler
Old 04-22-2017   #56
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Hell yea! Good luck on the dyno!
BW8776, e-85
Old 07-19-2017   #57
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Little update now since the car has been running. Put up on the dyno and we maxed out my single walbro 450 intank pump. Car put out just shy of 600 whp at 485 tq. The car is no were near its full potential at this power level but just cant push it more with my fuel setup. This winter i plan on adding a surge tank along with dss axles all around with a triple disk clutch. Then we should be able to make some real power.
Tyler
Old 07-19-2017   #58
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Ringlands in tact....tranny is holding up... Id call that some good streetable power...but if ya want more keep gunning!
David,
Old 07-19-2017   #59
dogwhistle
dogwhistle's Avatar
Can confirm car spools very well, with insane transient response. Lol awesome sounds too.
-Adam
aneujahr@maperformance.com
Old 07-19-2017   #60
Damn good power! Nicely done, what are you going to push it to with a new pump?
