10-26-2015
#181
Been there, done that.
Picts only.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
Best 1/4 - 11.7 on 93oct
Best 1/4 MPH - 120mph
11-12-2015
#182
Just a fuel hangar gasket and new clutch and break pedal pads arrived today.
Also Found Rear Black Leather Seats For The Car for $30 I'll Be Picking Up Over thanksgiving as I have to drive to Charlotte to pick up my brother at the airport anyways
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
11-30-2015
#183
Small update.
Brother came to visit for thanksgiving and we did gift giving.
I got a backup camera for the eclipse, on top of a dji phantom 2 plus.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
03-08-2016
#184
Well tax season has arrived again.
So far: order today
Moroso oil pan
AEM digital oil temp
12an fittings
New laptop as my old one took a dump
Depending:
Feal 441 road race coil overs might be next on the list.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
03-08-2016
#185
Nice, looks good! So glad to not see body kits and painted interiors anymore.
03-12-2016
#186
Picts oil temp and pan
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
03-12-2016
#187
Pan new style
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
03-13-2016
#188
I love a quality baffled oil pan, nice purchase!
05-08-2016
#189
Well small update.
New items added.
I got my 12an fitting welded to my moroso pan on friday.
Since I don't have the lock key for my lug nuts I bought new set of Mishimoto locking lug nuts.
-New brake fluid cap
-New clutch fluid reservoir.
-12an ftp oil drain setup.
I also painted the underside of my hood last week so it matches the rest of the car.
I'm also thinking about painting my valve cover and fp intake red also to match. And maybe the compressor cover
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
05-23-2016
#190
Well all new:
Gates timing belt kit installed with new oem tensioner.
All new accessory belts
moroso pan installed
Mishimoto lug nuts installed
-note the adapters that the aem digital oil temp come with won't work with the moroso pan. I'll have to order a 1/2 inch to 1/8 adapter.
Also my 12an fittings to finish up the oil drain line still haven't shown up. (Supposed to be here end of last week but are still on back order with extremepsi.com)
I was also very please to see that the Kiggly crank trigger was there as listed when I bought the car. (Should have taken a picture but slipped my mind)
As well as the car has at least poly side motor mounts. Which I wasn't aware of. They are black from dirt but where they were protected by the sides of the motor mount, the red was still nice and clear.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
05-23-2016
#191
Yea I had to run the same 1/2" to 1/8" npt adapter on my last car's moroso pan for the oil temp gauge, got it at a local plumb supply store for a buck or two, cheaper than the aftermarket suppliers wanted. Sounds like it's coming together.
06-02-2016
#192
Mishimoto 25 Row Oil cooler kit, came with the 12an fitting and 12an line I needed to make my oil drain with.
Only they still haven't shipped the 2nd 12an fitting I need to finish the line (been a month already)
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
06-05-2016
#193
Well got started on mounting my oil cooler today.
Got the sandwich plate mounted:
Just need a 27mm socket
And the M20 x 1.5 adapter from Mishimoto torqued to 40/lbs
Anyrate went to clean up that mess of oil lines under there as the sandwich plate has 2 ports you can use instead.
And when I went to tighten the turbo feed line to the oil filter housing I cracked it in half. So now I have to get a new forward facing oil filter hosuing.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
06-15-2016
#194
12an oil drain finally done.
(Months of waiting for fittings only to be to large for the distance between turbo and drain on the pan.
12an standard fittings won't work. Finally had to go with 12an push on fittings and then cut them down to size. And took a "press" at work to finally get the braided line onto them. Was a pain in the ass.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
06-22-2016
#195
Almost finished with the Mishimoto 25 Row universal kit install.
How to run the lines are the only issue left (fingers crossed I haven't tried to put the bumper back on yet though.
Currently the lines running/mounted behind the fmic I ran into an issue where they weren't long enough avoid the i/c piping (I couldn't rotate the fitting enough to clear)
Which was a huge let down as I thought I was all done.
Buy anyways here's the progress so far. If I can't get it to work on this location. I also fabricated brackets to mount the cooler between the FMIC and a/c condensor.
The only thing so far I had to change about the kit is I had to change out the "straight fittings, for a 2nd set of 90 degree fittings", the forward facing oil filter housing makes it so you need them.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
06-22-2016
#196
Update also - father's day I got around to installing the 2001 eclipse black leather seats. As well as the dodge avenger doors (black/grey that I dyed black) amd the black door handles and plastics.
The last parts I need to complete the black interior swap. Will be the dash, a pair of sparco racing Seats, Sparco Steering wheel with quick release, and black seat belts or harnesses.
I'll update the door picture to a better one later. The door is jet black. But the flash ruined the actual color of it in the picture.
I also got a new passenger side airbag to replace the one in the car that has the typical sun warp to it. Just have to install it
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
06-27-2016
#197
Finalized the install, bumper fit perfectly
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
07-05-2016
#198
Update - started the car for the first time since thanksgiving today.
After installing:
Moroso oil pan
Mishimoto 25 Row univeral Oil cooler
Moroso pan
New FFOFH
New 12an drain line
Removed the oil line clutter so it's down to just 2 lines.
Painted the hood
Installed new passenger airbag
And black leather
And after a minute of idle I found these 2 new oil leaks.
1- pan gasket (let it cure for 3 days prior to to putting oil in the car)
2- the big bolt at the top of the filter housing which I never would have expected to leak. (Or it could be a leak from the pan above it. Not sure)
I'll go out Thursday and see if I can see if the leak is frim the bolt or from above and is a 2nd pan gasket leak.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
07-16-2016
#199
Bored at work so I thought I'd do a preview posted vs.installed. (hasn't arrived yet)
I must have leaned on my stock coolant reservoir or just age. But when I started the car last time, I saw the coolant was leaking onto the ground (from sliding it in and out or me pusing to hard on it, as it has a hairline crack where it mounts)
So...
Mishimoto coolant reservoir is ordered.
I also didn't like the hose it comes with so ordered some Braided line for that
And while I was in the braided line mood. I went ahead and bought new Braided lone for my oil catch can, silver to replace the black on black. As I'm going with a silver/black themed engine bay.
I also needed another mounting solution for my oil temp gauge which I already have so I a bought an ortiz center vent dual pod. But there's a 6 week turn around on that. I'm pretty sure I'll be getting a Trans temp gauge to fill the last spot. But that will be when I have tmz build my tranny and do a custom cooling mod as well
Not sure if I posted it but installed my new airbag as the last one was warped from sun. I also installed a new driversidea door handle after the wife got a little to agressive when the doors were locked lol.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
07-18-2016
#200
Just a picture of the Kiggly crank trigger since I hadn't been able to get one till last night when I was.working on a leaky oil filter housing gasket.
1997 GSX - new ride
2004 R6 - sold
1992 GSX - sold
1996 GST - sold
1995 GSX - sold
| Thread Tools |
| Display Modes |
Linear Mode
