Old 11-06-2013   #21
93gtpeater
Drives: cbr 1000rr repsol
Re: Winter mods 2013/2014
You are planning on that t4 turbo in a couple months you will want to go to stock bolt on turbo and after a couple more months you will change your mind for a different turbo set up. You were talking about a ef3 or FP red like a month ago. Now you are back to t4 turbo. Pick something and stick with it.
Old 11-06-2013   #22
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Want to go AWD in my Talon. Add 272's as well.
BW8776, e-85
Old 11-06-2013   #23
Can we ban Murlo from this thread since we all know he will change set ups mid winter....
And once more at the end of winter, middle of spring, beginning of summer, mid summer, and middle of fall. no big deal.
Old 11-06-2013   #24
cmspaz
Walls need hugs too
cmspaz's Avatar
Oh, I almost forgot. I will eventually have to replace the burned out plate light on the Jetta. Eventually. Probably when they both burn out. Maybe not even then.
Originally Posted by Trogdor
Old 11-06-2013   #25
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I would still have my other t4 kit if I wasn't in a money pinch. I have done the research and the EFR is what I am going to go with, very little chance of changing at this point. I was looking at stock frames before as I thought they were the only thing I could get the desired low end out of the car and I found a better way to do that with the 7670.
But hey, if it makes you feel better I will delete my turbo kit from my list.
Old 11-06-2013   #26
93gtpeater
Calm down Murlo just giving you a hard time. I am just jelly I can't swapping turbo set up after set up. I have hard enough getting my stuff back together when something breaks.
Old 11-06-2013   #27
Finish putting the new intake manifold setup on and work out any bugs. Install ID2000's. Finish cleaning up the wiring. Get it tuned. Install front/rear lips, side skirts, and spoiler. Get car painted.
Then hopefully enjoy it for a few years like that.
Old 11-06-2013   #28
Murlo26
Murlo26's Avatar
I know how that goes. It's all good, I didn't have any caffeine today, im a little on edge
But I am pretty set on the new turbo to be honest.
Old 11-06-2013   #29
Install ID2000's.
Going for 40+ psi?
Old 11-06-2013   #30
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
'99 GS-T; fix suspension and sell.
'95 AWD Auto.; think about looking at it. Work my way to finishing the interior...then pull the engine. -.-
'95 Mirage; tear down, fix rust/body, get running.
'94 Colt; fix rust..?
'92 TSi; move. Do body work..sell..?
12 Valve; new tint, front tint visor, paint tail gate, get a decent head unit, better speakers, sub(s), K&N intake (or better), more fuel.
Old 11-06-2013   #31
On the owdee -Timing belt, water pump, thermostat and housing, rear coolant valve replacement, VC gasket, and a bunch of other maintenance, figure out why my power steering started to make a grinding noise at full lock in the next few weeks.
Decide if I want to keep it come spring and replace it with something else. Or get a second summer car.
This or ban.
Old 11-06-2013   #32
Going for 40+ psi?
No no, just feel like I'd be on the hairy edge with the 1000's, so upgrading to something with a little more breathing room.
Old 11-06-2013   #33
Murlo26
Murlo26's Avatar
ID has 1300's, are those not enough?
Old 11-07-2013   #34
Well I do have plans for the race car. I need a motor to last more then 1 season. So to do that I am going to limit my street boost to 40psi and running e98, plus a 75 shot if things go south. Then for track duty I will be going back to c/q16 and no more then a 150 shot, with any luck this will prove to add some reliability to the moon taxi, anything can happen at 8+ awhp per cubic inch. And all I want to do is back up my 9.45 run but now on slicks with a 1.5 60' vs 1.75 on drag radials, Any dang way back to posting Liana up dates.
Old 11-07-2013   #35
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Get my 2.3 broke in and tuned. Then some new sticky tires for drag/autox and some road course action. Thats really about it. Maybe a JDM rear bumper if all goes well
2006 WW IX RS 396/404 - SOLD
Old 11-07-2013   #36
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Old 11-08-2013   #37
1)Drop the rear cradle, replace rear bearings, active toe eliminator and all poly bushings.
2)Quiet down the exhaust a lot.
3)Repaint whole roof and add modern shark radio/GPS antenna.
4)Finish interior dynamat project.
5)Powdercoat RPF1's bronze.
6)Detail and paint engine bay
7)Powdercoat various engine accessories.
8)Upgrade brakes or pads.
Old 11-09-2013   #38
^ you should buy carls turbo
Old 11-09-2013   #39
URV8SUX
URV8SUX's Avatar
M&W pro 14 and coil on plug to control timing in each cylinder.
Rear wheel speed sensor.
Get better weight distribution front to back.
