Old 07-10-2013   #41
93gtpeater
Drives: cbr 1000rr repsol
Re: project darkness
Th350 will handle big power on a na motor. But on a turbo application I have heard them not holding up. Its possible to build a th350 to handle big turbo power but cost money and you have to find someone that knows what they are doing. But I want a transmission that will handle a lot more than I will make simple because I am real rough on stuff....
Old 07-10-2013   #42
4seasons69
4seasons69's Avatar
Lets put nitrous on this thing too!
v8 + turbo + nitrous = win?!
I second this motion
Old 07-28-2013   #43
93gtpeater
Well this a sad update. A buddy of mine rebuilt the transmission and fucked something up. I don't have second gear and the transmission over heats fast. Just after 1 pull I had transmission fluid all over the place. So the transmission need to come back out. But to make matters worse the motor started knocking. Sounds like a lifter went out. I have a buddy that works at the white bear lake super store. Hopefully he can figure out what it is for sure. Hopefully its an easy fix. If its not I will just pull the motor and replace with another 5.3. But I might just pull the motor band transmission out next weekend.
Old 07-29-2013   #44
shitty man. Good thing 5.3's are cheap?
Old 10-21-2013   #45
93gtpeater
Update. Picked up a new motor and a built th400 transmission. I finally got the new motor and trans in the truck now. Hopefully next weekend I will have the truck up and running. I still have a decent amount of stuff to do to get it running again. I found a transmission cooler at work that is 24 inches wide and about 12 inches tall. I need to find 2 10 inch fans to mount on the trans cooler. I am mounting the trans cooler under the truck that's why I am mounting fans on it.
Old 10-21-2013   #46
Very nice!!
Old 10-21-2013   #47
hell yeah man
Old 10-27-2013   #48
93gtpeater
Well I got pretty far with the truck today. A couple more hours and it should be done. I need to bend new transmission lines that go up to the front of the truck. Install starter, bolt tq converter to flywheel, drill new holes for my trans cross brace, install drive shaft, and hope it starts. Hahaha.
Old 10-28-2013   #49
93gtpeater
New transmission cooler and I painted the valve covers candy apple red.
ID:	14062   Click image for larger version
Old 10-28-2013   #50
b00sted_spyder
If you ever need your transmission rebuilt for big power, Paul at Proven Force knows his stuff. He's been building transmissions since the 80's.
Old 10-28-2013   #51
93gtpeater
I hope to god I don't need to do any more transmission work. This thing should be bullet proof for what kind of power I am making. But I will keep him in mind. I will hopefully be building another turbo Ls for my vette
Old 03-27-2014   #52
93gtpeater
Little update. Having a driveshaft built right now. So hopefully by next week the truck will be on the road. Just need the driveshaft and a new trans dipstick assembly. Iam going to daily drive it and fix a bunch of things this year if everything works smoothly.
Old 03-27-2014   #53
b00sted_spyder
Where are you having the driveshaft built?
Old 03-27-2014   #54
Awesome man, can't wait to see this beast on the road.
Old 03-27-2014   #55
93gtpeater
Universal Driveline inc. The place is on hwy 61 in whitebear lake.
Old 03-27-2014   #56
b00sted_spyder
What size joints are you putting in there? How much is the whole shaft?
Old 03-27-2014   #57
93gtpeater
Iam using standard u joints and he said about 400 bucks. He said I could go bigger but its pointless if I dont change the yoke on the rear end.
Old 03-27-2014   #58
Much excite to see this thing rolling for once! (my fault not yours)
Old 03-27-2014   #59
Git-r-done!
I are still want a ride in this sum bitch once you get it all together!
Old 04-02-2014   #60
93gtpeater
Got transmission dipstick today. Hopefully I can pick up my new driveshaft this friday. If everything goes as plan I can start driving it this weekend
