Old 04-02-2013   #101
Re: joel's build
What was the reason for using the extended bolts? Aluminum flywheel? I know some people using an aluminum flywheel use them because of the smaller thickness of the bolt surface. Some use extended bolts with the auto spacer plate, some just use regular length OEM bolts. Both methods seem to work fine, but I have heard of the extended ones bottoming out on some cranks, especially without the spacer plate.
Originally Posted by evotuner View Post
Compliments from GH? You must be doing something right haha
Btw great job man
Anyone doing their own work deserves some sort of pat on the back. Not something 90% of you evo guys would know about though.
Old 04-02-2013   #102
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Orderd the studs not knowing they. Where longer. They where about a 1/4" longer at the most. And when the flywheel was attached to the crank I used a screwdriver to determine how deep the flywheel and crank hole is. And it was deeper then the bolt is long. We will have to see going to mess with it tonight.
99gsxjoel is offline   Reply With Quote
Old 04-02-2013   #103
Re: joel's build
Yea, I think they are 3-4mm longer IIRC
Old 04-02-2013   #104
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Trans is going to come out tonight to find out what the issue is. I hope ot is easy to see what was going on in there.
Old 04-03-2013   #105
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: joel's build
Glad im in that 10% then
2006 WW IX RS 396/404 - SOLD
Old 04-04-2013   #106
Re: joel's build
right.
Old 04-04-2013   #107
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: joel's build
right.
I oughtta smack a hoe. lol...I actually do you homo. Aside from clutch jobs and tuning.
Old 04-04-2013   #108
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Well got a lot done today. trans got pulled and the flywheel studs where the issue. there was about 1/16" of play. The flywheel looked fine because It was only on for about 15 miles at max.
So Cornfed2.4 helped me get the trans back on with some oem flywheel bolts.
Tomorrow I need to install the intercooler piping, cross member, and exhaust.
Go get some gear lube for the trans, and it should be good to go.
Old 04-04-2013   #109
Re: joel's build
Good to hear it was something simple.
Old 04-04-2013   #110
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
It's close!
Old 04-05-2013   #111
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Well got it all back together. it was a pain in the ass today seemed like nothing wanted to be nice. couldn't get the cat back attached and got tired of trying so ripped it off. So I was already frustrated. Took it out for a short test drive, and now it wont idle down when I push in the clutch. So I called it quits.
Old 04-05-2013   #112
Re: joel's build
Taking a break when things start getting frustrating is a good idea. Glad you got it figured out man.
Old 04-05-2013   #113
blackawdtsi
Drives: 2G DSM
Re: joel's build
Did the idle switch get unplugged?
Old 04-05-2013   #114
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: joel's build
^^ I asked last night. Not sure if he checked it today yet or not.
Old 04-05-2013   #115
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Well some good news. I think the computer just needed to learn how to idle. Its running good. Now I dont know if I want to run strate 3" out the back or put the muffler back on.
Old 04-08-2013   #116
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Car seems to be running strong. The only issue I am having is it's still running worm on the highway. I am guessing I need some sort of air dam to force air into the radiator. Or find a way to make more negative pressure behind the radiator.
I set up a tune date for the 29th of this month so I am hoping the new turbo will make it here in time to install.
Old 04-08-2013   #117
93gtpeater
Drives: cbr 1000rr repsol
Re: joel's build
Get some of that becool radiator treatment. I had a car that ran warm and after I put that in it ran at less 10 degrees cooler
Old 04-08-2013   #118
99gsxjoel
Drives: 1999 GSX
Re: joel's build
I don't have a aftermarket temp gauge so its hard to tell off the stock one. But at idle it sits right in the middle. And on the highway it sits at the top of the flag. Ill have to have shane tell me what it is running at on the dyno.
Old 04-08-2013   #119
93gtpeater
Re: joel's build
Maybe you need to burp the cooling system
Old 04-08-2013   #120
99gsxjoel
Drives: 1999 GSX
Re: joel's build
Tried that today by letting it run for about 15 min with the radiator cap off. Got a few small bubbles out of it but nothing crazy. drove it for about a half hour and it still runs around the same temp. I am going to just wait till Shane hooks up the computer and gets a temp reading instead of guessing on the stock gauge.
