Old 08-23-2012   #201
Re: after 10 years its coming back to life
Man, it just seems so laggy and peaky. Did you have boost leaks or exhaust leaks? Did shane print you off a boost graph?
Old 08-23-2012   #202
No leaks at all. I do have brads old huge fmic on the car. The mbc that I had on there was not working right. Put on one of Shane's then the sensor blew out.
Old 08-23-2012   #203
oh ok
Old 08-24-2012   #204
95talonracer
95talonracer's Avatar
How does a sensor just blow out? Did you not tighten it??
Amsoil Dealer
Old 08-24-2012   #205
Know Idea why it came out. Everything was tight on the car. I drove it around for almost a week before the tune.
It is the bottom end check it out last night. It takes alot to turn it over with out plugs in it.
Old 08-24-2012   #206
cmspaz
Walls need hugs too
cmspaz's Avatar
It's a shame to see that motor finally give up the ghost from something so stupid.
Originally Posted by Trogdor
Old 08-24-2012   #207
Yep. The Spyder was the 4th car I had it in over the last 8 years. It will be fixed or replaced if I can find a good deal on a short block
Old 08-27-2012   #208
Back to the way it has been for 11 years
Engine looks like it will be a total loss.
Don't know if this happed when we lost all the oil or it was like it for a while. The engine has been in 4 of my cars and has been running for 8 years.
Old 08-27-2012   #209
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Ouch, well at least you got good use of the engine! What are the plans for it then? Just gonna throw another 2g/1g combo in it?
Old 08-27-2012   #210
Don't know right now. Going to see if I can find a good short block now to get it back up ASAP. To bad I sold my built bottom end that I never put together for the car last winter.
Old 08-27-2012   #211
Things I want to say: lots
Things I can say that will help: not much
Things that will cheer you up:
-32 oz of beer
-nice weather
-we finally got to hang out yesterday
-32 more oz of beer
-puppies
-spaz, you can't help but laugh and smile with the kid
-theres more 4G63's out there
-cantaloupe (seriously how did I spell that right?)
-the shocker
-aids (c'mon, you laughed)
-meat
-freedom
Old 08-28-2012   #212
I've got a fairly fresh 2G piston/1G rod shortblock available if you're interested.
Old 08-28-2012   #213
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I seen you going through the wi boards looking for a short lock if I find one I'll pm ya a link
Looking for a 6 bolt or late 7.
Old 08-28-2012   #214
Let me know what your looking to get Steve
Nick just a 6 bolt.
Old 08-28-2012   #215
95talonracer
I have a 6 bolt short block that ran when removed but the pistons have some minor valve contact. It will buff out.
Amsoil Dealer
Old 08-29-2012   #216
Thanks for the offer guys. I am going to pick up Steve's spare short block.
Old 09-04-2012   #217
Picked up the new bottom end yesterday from Steve. It is the same set up I had in the car. 2g pistons on 1g rods. Just need to get a oil pump and put it together.
Also got the new 10an oil cooler put on with new brackets. It is a lot bigger than the 8am cooler that was on the car.
Will be dropping the head off today to get cleaned. Will be back running soon
Old 09-04-2012   #218
Looks good! Thanks for helping clean up my garage!
Old 09-04-2012   #219
No problem. Thanks for the good deal
Old 09-04-2012   #220
New ppi amp 5ch picked it up for 50.00 off of mnsc
Put all the speakers back in the car all Boston pro's also rewired the stock dash speakers to run them off the deck.
Rear 4.5 Boston pro
Front 6.5 Boston pro.
