Old 08-18-2012   #21
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Built 2G DSM Part Out (35R, big brakes, Shep trans, etc.)
^^^ what are you talking about?
Speedfreak yes a 2 g trans fits in a 1G. But a 1g will not fit in a 2G because 2gs having 3 mounts on the trans and 1gs have the mounts on the block.
Make sense. I don't know what dudes taking about with 2ga and 2Gb yeah the t-cases need to be matching with yrs. But not related at all to your question asked.
Old 08-18-2012   #22
Speedfreak
Drives: four tires
Originally Posted by punxnotdead185 View Post
Being this car is a 2GB and not a 2GA a tranny swap between generations is a little more difficult. You will for sure need the 2GB transfer case with the 2GB transmission being that they changed the final drive in the trans in 97 and instead of changing the rear end ratio to match they made up the difference by changing the gear ratio in the transfer case. And I believe you need both the 2GB starter plate and possibly the bracket for the shifter cables. It is not a direct swap but it can be done if you get all the associated parts to go with it. Do some research and you should be able to find out what you need Dave to include with it so it'll work.
Thanks for the info, much appreciated.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 08-19-2012   #23
DavidPHumes
Drives: Turbo LSx FC RX-7
Updated OP with a few more parts and some more pictures. I also sold a few things, so I removed those. Don't be afraid to make offers. Some people have and ended up getting good deals. I just want this stuff gone!
DavidPHumes is offline   Reply With Quote
Old 08-19-2012   #24
DavidPHumes
I decided to part out the long block. See the OP. The shortblock isn't for sale yet until I pull it out and make sure it looks good. The deck looks good, no cracks but that doesn't tell much of the story.
Old 08-20-2012   #25
jrohner
jrohner's Avatar
Any interest in selling the head w/o the cams & gears?
Any details on the porting job?
Old 08-20-2012   #26
DavidPHumes
So you just want the head with the valve springs installed? I could probably do that. All I know is it's been ported, polished and gasket matched... I'm in the dark as to the details of the port job otherwise.
Old 08-20-2012   #27
I might be interested in the cams if you seperate them.
Old 08-20-2012   #28
DavidPHumes
Sounds good... I'll let you know.
Old 08-21-2012   #29
DavidPHumes
Bump... sold a bunch more stuff, updated the OP.
Old 08-22-2012   #30
DavidPHumes
Sold some more stuff, I will be in the cities this weekend if anyone wants anything brought down.
Old 08-22-2012   #31
portum89
portum89's Avatar
Drives: 1999 Eclipse Spyder Gst <p> 2006 Bmw E90 325xi
still got the roller? interested on roller, trans and bottom end ill pm u
95 talon tsi awd...pte scm 5031 /950ccs on corn / gsc s1's / comp stage 4 / 12.8 @113mph - SOLD
99 Spyder GS-T 16g / 264's / 550ccs / Reflash OWN
portum89 is offline   Reply With Quote
Old 08-23-2012   #32
DavidPHumes
Yup, still do. PM'd you.
Old 08-26-2012   #33
DavidPHumes
Make offers!
Old 08-30-2012   #34
DavidPHumes
Bump, the complete head is sold.
Old 09-07-2012   #35
DavidPHumes
Sway bars (front and rear), shortblock and oil cooler sold.
Old 09-16-2012   #36
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
specs on wheels? offset and width? they 5x114 and 5x100?
Originally Posted by 311evo
Old 01-23-2013   #37
tsiawd
Drives: 2g & mb c300
Do u still have the turbo and gate if u do pm me
tsiawd is offline   Reply With Quote
Old 01-23-2013   #38
dsmreck
dsmreck's Avatar
Drives: 98 gsx
do you have a tb? if so pm me
Old 01-24-2013   #39
99gsxjoel
Drives: 1999 GSX
old bump but what the hell. Do you happen to still have the trans?
99gsxjoel is offline   Reply With Quote
Old 01-24-2013   #40
slammedndirty
slammedndirty's Avatar
Drives: 93 laser rs awd
pm sent for the wastegate
slammedndirty is offline   Reply With Quote
