Old 08-16-2010   #1
Part Out - 10sec 600hp 1991 Talon AWD
keep all the questions, requests, etc IN THIS THREAD if possible . Please don't PM me saying you want this and that because it gets very confusing. I'd like to keep as much as possible in this thread. Or if you absolutely need to, you can PM me or call me at 612 384-1425
3" Vibrant resonator - $40
Forge BOV (pretty sure I have the spring kit for this as well for various psi setups) - http://mitsustyle.com/forums/attachm...2&d=1233977461 - $95
Universal Coolant Overflow bottle - $15
Greddy white face EGT gauge and probe (appx 6 years old) - $35
Beatrush solid driveshaft bushings, brand new (fits EVO and DSM) - http://www.maperformance.com/beatrus...051pmb-2t.html - $40 - Pending Sale
10" Hayden Fan - few years old - you can see a pic of it laying on the floor in the 3rd picture of the motor above - $10 - Pending Sale
Starter - $10 - Pending sale
Feel free to make offers if you feel something is priced too high. I feel like I priced it all very competitively, but am willing to listen to offers.
Items that have been sold
Eagle/Mahle 2.0L short block originally built by MAP, E85 has kept the piston tops pretty deng clean. Compression was 165 across all 4 before removed (this was with 272's installed), exterior of block was painted black by MAP - Please contact me via phone or pm for more info regarding this - What is pictured is what you will be receiving (minus the knock sensor), which is why I took pics at different angles - $800 - Sold
HKS 272's - $275 shipped - Sold
17x8 35 offset Rota Boost rims (bronze) w/ Sumitumo HTR Z3 tires (235/45) - tires are nearly new, lots of tread left - $675 - Sold
ETS FMIC 3" thick, about 1 year old, still looks damn near new - $360 shipped - Sold
3" Pypes resonator - $40 - Sold
3" Magnaflow muffler w/ tip - $40 - Sold
PLX Wideband - will include a used and brand new sensor - $190 shipped - Sold
SW white face Boost gauge 30-0-40 (1 year old) - $45 shipped - Sold
Stock 6-bolt flywheel & A/C bracketry - $20 - Sold
SS Turbo oil feed line - - Appx 3 years old - $10 - Sold
Eibach Sportlines w/ KYB AGX's - $375 - Sold
Tial 44mm Wastegate ($300 new) - $210 shipped - Sold
SLS T3 Mani - lifetime warranty - $425 - Sold
S362 (.70AR t3 V-band out) - Turbo has the normal little bitty shaft play. Will include the push-lock drain line, as well as the drain and feed adapter fittings. Feed line not included - short vid available upon request but please only ask me to send it if you are seriously interested - $625 shipped - Sold
Two 10" FAL fans- $35 - Sold
Pair 6x9's - $20 - Sold
Mishimoto Rad Cap - $15 - Sold
Aeromotive AFPR kit from Import Evolution - $120 - Sold
Taylor 10mm plug wires - will include a new set of 4 NGK plugs for free with these - $40 - Sold
Powder Coated Valve Cover (will also include the upper timing and spark plug covers which have been spray painted to match the VC) - $55 - Sold
Golan -6 fuel filter and -6AN nylon braided fuel feed, stock 1G fuel rail with AN fitting attached for feedline, and fittings that allow the Golan to attach to the stock lines (see pics) - $100 - Sold
Homemade Mini Battery setup - $100 - Sold
CF Hood (w/ CarbonTrix Vent) - $400 - Sold
Brand new Napa Front Pass Axle, still in the box - $35 - Sold
JMF 1G front bumper replacement thingy - $130 - Sold
Brand New OEM Mitsu Plug Wires - $40 - Sold
Tubular front crossmember - $150 - Sold
JMF Race SMIM - $360 - Sold
PTE 1600's - $190 - Sold
Two Walbro 255hp pumps - $120 for the whole setup - Sold
ARP L19's (used for 1 year) - $150 - Sold
ACT2900 PP - The clutch disc was pretty much spent, so just selling the PP. It's used, but could be roughened up and reused - $25 - Sold
Dynatek Arc-2 ignition box - Plug n Play harness for a 1G (not sure if it's the same between 1G and 2G) - $300 - Sold
4" CAI - This was custom made by MAP (= expensive), places the MAS in the fender well, fits perfectly with my S362 but may require slight tweaking to line up with your turbo setup. I tried to show how it also has a bracket right before it bends down into the fender well, that bolts to the body which holds it nice and steady - $100 - Sold
External Oil Cooler and lines (pushlock) - $120 - Sold
CAS - $15 - Sold
Interior Seat Swap - $60
EPROM ECU w/ Keydiver chip - $230
Rolling Shell - SOLD locally!
w/
- Rear Subframe with Jay Racing Toe Eliminator installed.
- 1GNT Throttle Body
- 4-Bolt Rear End
- Adjustable rear upper control arms
- Shifter Bushings
- Tinted Tails
- Evo8 MAS w/ pigtail and 4" adapter coupler, and KN Filter 3 yrs old w/ MAS adapter flange
($1000 rcvd)
DSM 3rd Gen design lifters - appx 5k miles on them - $50 shipped - Sold
Cobra front brake kit. This will include calipers, brackets, bolts and washers, black braided 2G lines, and rotors (rotors have some surface rust where the pads don't contact) - $475 shipped - Sold
Apexi Turbo Timer w/ harness for 1G - http://www.maperformance.com/apexi-turbo-timer.html - $55 shipped - Sold
Stock Coolant Pipe with turbo feel line welded shut by MAP (good for people running oil cooled turbo setups) and used Knock Sensor - $35 shipped - Sold
Evo Shift Knob - $22 shipped - Sold
2G Head & 90 Oil Filter Housing. - $381 shipped - Sold
Mishimoto Alum Radiator - $150 shipped - Sold
Stock oil pan modified with a -AN fitting welded (by MAP) for the oil return & JMF dual chamber catchcan setup - $93 shipped - Sold
2 new OEM driveshaft carrier bearings from the dealer, - $125 shipped - Sold
TRE Stage 1.5 tranny w/ 4-spider center diff, - $600 shipped - Sold
DSMLink V2 with USB cable (no computer included)- $190 - Sold
A/C compressor (has fitting on it for Freeze 12 conversion) - $40 - Sold
Alternator in good working condition - $20 - Sold
ID:	10461   Click image for larger version
ID:	10465   Click image for larger version
ID:	10467   Click image for larger version
ID:	10468   Click image for larger version
ID:	10607   Click image for larger version
ID:	10608   Click image for larger version
Old 08-16-2010   #2
Re: Part Out - 10sec 600hp 1991 Talon AWD
Texted you back. Let me know what your plan is because there are a lot of others already interested in it. But of course I'd prefer to sell locally so let me know what you're thinking.
Also, I'm getting some PM's for stuff. Like I said above, please try and keep it in this thread. It makes it so much easier for me I think.
I'm adding some pics as well. Will continue to add pics as I get them.
ID:	10470   Click image for larger version
ID:	10472   Click image for larger version
ID:	10612   Click image for larger version
ID:	10613   Click image for larger version
ID:	10615   Click image for larger version
ID:	10616   Click image for larger version
Old 08-16-2010   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Can I get pics of the hood? You wouldn't take payment plans for it would you?
-1990 Mitsubishi Cyborg 4WD-
Old 08-17-2010   #4
I'll take the small battery setup I texted you about. Do you take paypal? If so I can send you money ASAP and pick it up whenever. If not, I can make some plans to pick it up on Wednesday if you are around.
Old 08-17-2010   #5
Spoke to you over PM. I will get some pics tonight.
ID:	10491   Click image for larger version
ID:	10522   Click image for larger version
ID:	10619   Click image for larger version
ID:	10620   Click image for larger version
ID:	10622   Click image for larger version
ID:	10623   Click image for larger version
Old 08-17-2010   #6
I will get you pics of the battery setup. I'd prefer cash over paypal as paypal likes to dip their hands into the transactions
I'll get you pics, if you want it I'll just consider it sold and hold it for you.
But as far as picking it up Wednesday, I don't think that'll work because I plan to start disassembly next Monday. I'm enjoying the car for the rest of this week like I said in the first post.
ID:	10512   Click image for larger version
ID:	10513   Click image for larger version
ID:	10515   Click image for larger version
ID:	10516   Click image for larger version
ID:	10518   Click image for larger version
ID:	10519   Click image for larger version
Old 08-17-2010   #7
Ok, I can send you the money as a gift so they don't get their cut too
I can also give the guys at Primo some cash when they come pick up my car tomorrow and give them an extra $10 for gas money or whatever if you wanna bring it over there at your convenience, that way they can just hand you the cash.
Old 08-17-2010   #8
Primo is only 5 minutes from my work. If you want to give them the cash, then sure I can just get the money from them and drop off the battery kit with them, but don't worry about $10 gas money.
ID:	10524   Click image for larger version
ID:	10525   Click image for larger version
ID:	10527   Click image for larger version
ID:	10528   Click image for larger version
ID:	10530   Click image for larger version
ID:	10531   Click image for larger version
Old 08-17-2010   #9
93gtpeater
Drives: cbr 1000rr repsol
I want the oil cooler set up. When are you avaible?
Old 08-17-2010   #10
tehehodi
Braaaaaaaap!
tehehodi's Avatar
Drives: '09 Silveraydo
Is the shell getting crushed? There isn't a price for it.
Old 08-17-2010   #12
I'd be interested in the shocks, springs, wheels, rear control arms, possibly the entire dual walbro setup. I am pondering, but just letting you know I have interest.
Old 08-17-2010   #13
Speedfreak
Drives: four tires
Hey Brandon, like I mentioned, I'd like the Taylor wires for sure, and I'll pick up the radiator cap for sure as well(for my cousins 1g, he may want some other stuff, but he'll contact you about that.. screen name Launchhard).
We'll chat about the tranny, if someone comes with cash, sell it, otherwise I'm very interested.
Oh, and yes, I think the intercooler may be a good option/fit for your next project(may need a little work on the inlet/outlet, but worth keeping IMO).
Old 08-17-2010   #14
Pics added of the CF Hood for those asking for pics. Like I tried to mention, the vent needed to be trimmed to fit around my manifold, and near that trimming you can see a slight brown from the heat. But it's nothing really.
And if you don't like the trimming, the vent was boughten from CarbonTrix, and you can just buy a new one for like around $90 and rivet it in.
Also added pics of the battery kit. I had the JMF one at first, but it doesn't fit right if you still have A/C. So I made this one myself, and so it fits with A/C.
So now some of you are saying you're interested, but now that you've seen the pics, let me know if you are still interested and I'll place you as the pending buyer.
FYI, there's 2 people interested in the battery kit, and 2 people interested in the hood. So the sooner you let me know, the better because there's multiple people asking for them.
ID:	10534   Click image for larger version
ID:	10535   Click image for larger version
ID:	10537   Click image for larger version
ID:	10538   Click image for larger version
ID:	10540   Click image for larger version
ID:	10631   Click image for larger version
Old 08-17-2010   #15
Again, this thing is getting disassembled on Monday. So anytime after Monday. I'll put you as pending sale so you have dibs. If you don't want it, let me know asap so I can take your name off of it.
FYI the oil cooler kit will include the cooler, the lines, and the fittings that go into the 90 OFH. But it does NOT include the filter housing. If you want the housing as well, let me know and we can talk.
ID:	10644   Click image for larger version
ID:	10645   Click image for larger version
Old 08-17-2010   #16
Sounds good. I won't put you down as the pending buyer since you're just thinking about it. But let me know if you do. Just an FYI that there are others also pondering those control arms and the pumps. So if you really want them, let me know because the first person to tell me they 100% want them, they will get dibs.
Old 08-17-2010   #17
I'll be giving Blageo money for the Battery kit tomorrow. You can pick it up at Primo after work tomorrow and drop off the battery any time in the next couple weeks.
Edit, I'll give him money for the Golan Fuel filter setup also if that isn't taken.
Old 08-17-2010   #18
Originally Posted by blackrosenova400 View Post
I will take the pressure plate/clutch pending removal/inspection.
Sounds good, I put you down as the pending buyer, and we'll see what she looks like when it's removed!
Old 08-17-2010   #19
Will do! Keep in mind I bet Blaine is closer than Primo though, so if you want to just come pick it up here in the next couple weeks it might save you a couple minute drive.
Old 08-17-2010   #20
OK I've added a bunch more pics. If you don't see your name next to something, that means somehow I missed that you wanted something, or it didn't sound like you were 100% serious yet.
So let me know ASAP if you want something 100%.
